Here's the tail of the log from the osticket-published docker container, which was last updated three years ago. It would be wonderful if someone could update the osticket-owned public docker image.
PHP Notice:  Constant INCLUDE_DIR already defined in /var/www/src/bootstrap.php on line 356
PHP Notice:  Constant SETUP_DIR already defined in /var/www/src/bootstrap.php on line 358
Configuring mail settings
OSTicket cron job is set to run every 5 minutes
Using external MySQL connection
Waiting for database TCP connection to become available...
Connecting to database mysql://osticket@osticket-mysql.xxxxx.amazonaws.com/osticket
Loading installation secret
Updating configuration file
Installing database. Please wait...
PHP Parse error:  syntax error, unexpected '=' in /var/www/src/public/include/class.forms.php on line 4057
Parse error: syntax error, unexpected '=' in /var/www/src/public/include/class.forms.php on line 4057```
    mistermocha
    We do not own that docker image nor the account. We don’t use docker at all. Someone claimed our namespace and added their own image. We are in the process of recovering our namespace. You will need to contact whomever created the image directly as we cannot assist you.
