Hello,
can someone help me to read a variable out of the DB?
For example I can easily read out the $ost->company variable like its used in the footer but I can't read out the helpdesk_url
BR waczny
  • waczny
    First, you wouldn't use __() as this is used for translation; URLs can't be translated. Second, if you look at the examples of usage in the code you'd see you can call it on the $cfg global (eg. $cfg->getBaseUrl()). If $cfg isn't available in that file then $ost should be in which case you can do $ost->getConfig()->getBaseUrl().
    I found that too, but how can I use it in the footer too as an example?
    <?php echo __('????'); ?>
      waczny
