Please check here once but still the same
Please don't mind guiding me step by step if possible
Thank you in advance
    Subrahmanyam-avance
    That is quite strange. I had someone with this issue using Asia/Kolkata and we changed the database timezone to UTC (not +00:00) and that fixed it. Can you try maybe setting your PHP timezone to UTC as well? Also, share a screenshot of Admin Panel > Settings > System > Date and Time Options section.
    Subrahmanyam-avance
    Do you have any browser extensions enabled? If so, can you please disable them and retest? Can you try a different browser altogether?
    Can you please share a full screenshot of Admin Panel > Dashboard > Information?
    Subrahmanyam-avance
    That is quite strange, I cannot replicate this. What does your Admin Panel > Settings > System > Date and Time Options section look like?
    I cant replicate it. The other places I would check, besides your profile:
    In Admin Panel, Settings, Default TimeZone. This should be Asia/Kolkata
    The server time config. On Ubuntu, execute "date" and make sure the server shows the correct time zone, +5:30.
    On my system, php.ini timezone isn't set, which is the default. osTicket Information shows UTC.
    In MySQL, SELECT @@global.time_zone returns 'SYSTEM'
      From the date command, the server has the wrong timezone. In this case, IST means Israel Standard Time (+2:00). If the times are 3:30 off, this is the cause.
      Use the timedatectl command to set Ubuntu to your local timezone. For example, 'timedatectl set-timezone Asia/Kolkata'
        Hi TonyO Actually we are facing an issue with the task due time. we select some date and time then update. but It updates at different time
