is there any option to disable users to edit their tickets ?
Disable ticket editing
You can make most fields non-editable to Users via the Field Permissions. Go to Admin Panel > Manage > Forms, click a Form, click Config next to a field, click Settings, then configure the permissions.
You cannot completely disable edit natively. If you want to accomplish this you must modify the code.
thank you it works
you can close the ticket now
ntozier locked the discussion.
