You're right, i have commented out this lines:
// Make sure mime type is valid
//if (strcasecmp(FileObject::mime_type($file['tmp_name']),
// $file['type']) !== 0)
// return false;
and it works.
It have checked the old source 1.17.1 -> This lines seems to be new in 1.17.2 or 1.17.3.
Many thanks for your help.
    jothie
    Yes, it's a security patch. But it's very strange that I'm able to upload this and you are not. I wonder what the difference is here.. 🤔
    jothie
    Can you please create a PHP file in your osTicket directory, paste the following content, visit the file in the browser, and tell me what the page displays?
    <?php
    var_dump('finfo_open exists: ', function_exists('finfo_open'));
    jothie
    That would be the only difference but you have that method as well so I'm not sure why you can't but I can without making any changes...so odd. Can you download the example you uploaded to the Forum and retest with the downloaded ZIP? I wonder if uploading it here fixed the MIME Type.
    Downloaded and tested - no change.
    But i have tested it on a mac - there it works.
    But on every W11 PC i tested -> failed.
      5 days later
      8 days later
      The problem ist that $file['type'] and FileObject::mime_type($file['tmp_name']) do not return the same result.
      in case of a zip-file:
      string(28) "application/x-zip-compressed"
      string(24) "application/octet-stream"
      samplefile attached
      tmp.zip
      115B
        bauernbengel
        Yes, I have seen this with someone else, however I’m unable to replicate this with ZIP files in my instance. What version of PHP are you using? What browser are you using? What OS are you using when uploading the file?
          Ugly Fix:
          class.forms.php replace the function
          static function isValidFile($file) {
              #var_dump($file['type'], FileObject::mime_type($file['tmp_name']));die;
              #if (!empty($file['type']) && strcasecmp(FileObject::mime_type($file['tmp_name']),
              #            $file['type']) !== 0)
              #    return false;
              // Check invalid image hacks
              if ($file['tmp_name']
                      && stripos($file['type'], 'image/') === 0
                      && !exif_imagetype($file['tmp_name']))
                  return false;
              return true;
          KevinTheJedi do you used my ZIP-file?
          osTicket-Version osTicket FREE v1.17.3 (ca95150) Patch-1 — Deutsche Version — Aktuell
          Server-Software Apache/2.4.51 (Unix)
          MySQL-Version 10.3.32
          PHP-Version 8.0.23
          Browser: Opera,Vivaldi,Chrome
          OS Win10/Win11
            bauernbengel
            If I were you I’d install a vanilla osTicket and retest there. We do not support the German version. They make customizations to the code so it’s not official osTicket.
