13 days later
Hi all, this issue is same with me. my agent can't see all attachments that have been attached on osTicket to his email. I made a test by attaching a lot of images and it doesn't send to the email, but if I attach 1 image it works fine. the condition is reversed if the agent replies with an email and all the pictures are on osTicket. Are there any settings that need to be configured?
osTicket v 1.17
Thank you
    enggal
    If you have the setting enabled to Email Attachments then it should be working. If it's not then you will need to check things like your PHP settings (post_max_size, upload_max_filesize, etc.) and your webserver settings (LimitRequestBody, etc.).
    3 months later
    I think I found a bug.
    At least in my installation, it happens.
    When I write the note or reply and then upload the attachment, everything works fine.
    If I upload the attachment and then type the text, the attachment disappears after the post and nobody receives it.
    Server Information
    osTicket Version v1.16.5 (b48bf7e) — Up to date
    Web Server Software Microsoft-IIS/10.0
    MySQL Version 5.5.45
    PHP Version 8.0.0
    PHP Extensions
    imap Used for email fetching
    xml XML API
    zip Used for ticket and task exporting
    PHP Settings
    date.timezone Europe/Athens
    Schema osticket (ticketsrv)
    Schema Signature c37e165651dc289240fee7d244990ac1
    Space Used 412.55 MiB
    Space for Attachments 218.50 MiB
    Timezone GTB Standard Time (Interpreted as Asia/Beirut)
