You're using a ticketing system to generate emails to a ticket system?
osTicket doesn't close tickets automatically.
Does your close status allow reopen?
5 days later
Hi! Here:
You're using a ticketing system to generate emails to a ticket system? Yes
Does your close status allow reopen? Yes
Upgrade to current and see if the problem goes away.
    9 days later
    Not still open closed tickets from zendesk after update.
    Any ideas?
    12 days later
    Any help to this problem?
    Here is one answer from zendesk:
    Not any filter even react to this.
      6 months later
      It sounds like there may be an integration issue between Zendesk and OSticket, which is causing the status of the ticket to not update properly. One potential solution is to check the integration settings between the two systems to ensure they are set up correctly.
      Another solution is to manually update the ticket status in OSticket when a Zendesk customer replies. This can be done by assigning the ticket to an agent or by changing the status to "open" manually.
      You may also want to reach out to Zendesk support or OSticket support for assistance in resolving this issue. They may be able to provide more specific guidance or offer a solution to this problem.
      Capcut Mod Apk https colon slash slash itscapcut dot com slash capcut dash mod dash apk and Resso Mod Apk httpscolon slash slash resso dash mod dash apk dot com
      You can also download from https colon slash slash modapktv dot com
      **POST EDITED by FORUM ADMIN (ntozier)
      removed embeded links and urls.
      preserved urls in human readble format.
      ** THESE URLS HAVE NOT BEEN EVALUATED AND YOU USE AT YOUR OWN RISK ****
        6 months later
        Hi! We removed following part of code, and it started to work.
        But do you know could this make harm for something?
