KevinTheJedi Hi, can you elaborate on that question please?
Also, now the IMAP stopped fetching emails, nothing has changed and it says Host not found (#11001): imap.gmail.com
SMTP Server not sending emails after changing internet provider
Deather Host not found usually means DNS issues. By shared host I think ( but not certain) that he is asking if you are using a shared hosting platform for this.
I’m asking if you use a shared hosting platform or if this is is a sever you host in house. If you use shared host they typically have SMTP restrictions. If this is the case you’d need to reach out to your hosting provider to have them lift the restrictions.
Since that domain can’t be found (it’s a completely valid domain from Google) it appears you are having network/DNS issues on your server. You need to resolve your network/dns issues and you should be good.
I don't know how in the world smtp.gmail.com
is working for IMAP for you. I've never seen that before. Typically it's imap.gmail.com
that's how I have always been using it and never had any issues
I think it's because Gmail uses the same server for IMAP and SMTP and I am setting IMAP Port 993.
Addresses: 2607:f8b0:4004:c06::6c
172.253.63.108
Addresses: 2607:f8b0:4004:c17::6c
2607:f8b0:4004:c17::6d
142.251.163.108
142.251.163.109
That's very weird of them then lol Why don't they have just mail.gmail.com
or something generic if it's like that?
ramrajone Not sure how you are seeing that they are using the same server for smtp. and imap. Those are completely different IPv6 and IPv4 addresses and I get different ones than you. My guess would be is that both sets of ports are open on each server and then the backend routes it correctly. I agree with @KevinTheJedi though, they could just have a mail.gmail.com and be done.
Hello everyone, after a while we managed to solve our issue. Our main issue was the HELO. No matter what host we picked, it always said HELO error. So I found a workaround and now the system is working flawlessly.
What I did is, got inside the OSticket folder, got into the Include folder and then into the Pear folder. Then went inside the Mail folfer. There I found a file called SMTP.php. I edit the file, to be more specific, the line 134
That is what the file said by default. I changed the string from localhost to “computername.domainname.com” (The FQDN) and now it just works.
Thank everyone for your help! Hope this helps someone else too!
It seems like the issue may be related to your SMTP configuration after switching providers. Double-check the SMTP server settings in OSticket, including authentication, port, and encryption methods. If you recently changed your ISP, ensure they are not blocking the SMTP ports or IP. Try reaching out to DigitalAka or Mailgun for further troubleshooting.
