what protocol do I use to connect to Active directory ?
Help AD
I have a task : Can the selected system be connected to AD? If so, using which protocol?
Yes, you can use LDAP/AD for authentication and lookup in osTicket. We have the Authentication :: Active Directory and LDAP plugin available on our website for download (under the Plugins tab).
As far was "which protocol" you will need to be more specific on what you are looking for.
KevinTheJedi added the osTicket 1.16.x (End Of Life) General Discussions 1.16.3 tags and removed the osTicket Latest News help tags.
I got an assignment from my boss to find out what protocol can be used to connect the system to the active directory? I don't know how to better specify
overall, what protocol Osticket uses to connect to AD
