voke254
Also what is your fetch frequency and cron job execution time? It might be a case of multiple cron jobs executing in a short amount of time.
    @voke254
    I would recommend setting your cron job and the Fetch Frequency every 3-5 minutes to make sure all emails are processed within that time. It could be that not all emails are processed by that 1 minute so when cron executes again it will pick up the emails that weren't done yet which would duplicate them.
      voke254
      Fetch less emails at a time. What I think is going on is your system sometimes can’t process all 8 emails within 1 minute and another cron job fires, picks up the email(s) that aren’t done yet on the first one and creates a duplicate ticket.
      Typically duplicates are caused by multiple crons running at the same time or if you have a cron job running and Fetch on Autocron enabled. You said autocron is disabled so it has to be a case of multiple cron jobs.
        I've seen what Kevin is describing before, and agree that it sounds likely.
        Hello KevinTheJedi . I tested on the above and fetched less but still got duplicates. I have set fetch frequency to 3min as suggested and am currently testing on this. I will give you an update once done.
        Hello ntozier , I tried with 2min fetching 8 but still got duplicates.
        KevinTheJedi I Set it to 3min and set cron to 3min. I have not seen duplicates since changing the time. Thanks.
        2 years later
        I tried all the above things on OST1.17 (cron and fetch 5 minutes and 5 emails) and I get duplicate tickets creation on every cron run.
        Two tickets are created:
        1. One that has an ID and can be accessed correctly.
        2. A second one that has a different ID and cannot be accessed or found in the system. When you try to access that one by clicking on the email message link you get a "ticket: Unknown or invalid ID."
        What is going on, please help.
          giannopk
          You either have a setup issue or you have both email fetching options enabled (you should disable auto-cron option if you have a cron job/scheduled task) or you have multiple instances of cron running at the same time. You need to confirm you only have the one Email fetching option Enabled and that you only have one cron job running. You can set your Default Log Level to DEBUG, wait for the cron to hit, and check your system logs to see if you see duplicate cron runs in a short amount of time. You should also ensure your cron job is set to an adequate time like 5 minutes so it has time to fully process all emails in the queue before triggering another fetch.
          Kevin you are right.
          In our case the problem was caused by having 2 cloned servers, a development and a production. Both were monitoring the same mailbox and both had their cron jobs setup. But the development server is not accessible from the internet, only locally.
          When a ticket was created by email-to-ticket, each OS instance was monitoring the same mailbox and was creating it's own ticket and notified the ticket creator (which got 2 tickets, one from the dev and one from the live, with different numbers). However, the ticket creator browser, only knows the live server address, and can only access one of the two tickets created, that on the live server. Trying to click on the dev server ticket link in the autoreply email, links the ticket creator to the live server with a ticket number that does not exists in the live server, but only in the dev.
          The problem was fixed by commenting out the cronjob line in the dev server and disabling email fetching options on the dev (plus autocron).
          I hope the answer will help someone with the same problem.
          Honestly in my experience, this is the number one cause of dupe tickets. 🙂
