Hi all.
Meanwhile I tried to install the previous version of osticket and...IT WORKS!
I also tried to install the same version on one other web space with windows os and...IT WORKS.
I made the same step but I note that this guide is not so precise: [https://docs.osticket.com/en/latest/Getting%20Started/Installation.html]https://docs.osticket.com/en/latest/Getting%20Started/Installation.html)
They wrote:
_
osTicket installer needs to be able to write and modify ost-config.php found in the include directory. Please follow the instructions given by the installer.
_
But the file does not exists in the folder. Exists ost-sampleconfig.php so I create a new file named as expected and tried to change the value in it. During the installation process osTicket for sure wrote in it again the same parmeter I put in the form. At the end as you all know was not possible to log-in in the admin panel
Using the older version of osTicket and changing the server version from Linux to Windows, I tried not changing the naming of the file I said above. During the installation progress I obtain a message that said me to rename the sample file!
After the file rename I continued the process and finished it.
As I wrote, It works.
