cocoon
One thing to check is to see if MS is forcing you to use Modern Auth (OAuth). If so, then you will need to disable this.
    5 days later
    6 days later
    Basic Auth will be disabled this year by default. and cant be turned off what i read in MS docs.
    @WeConnectIT
    Currently this is only for new accounts. Basic Authentication will be completely disabled by May 22, 2022 for all existing accounts. We aim to have Modern Auth (OAuth2.0) support by that time.
    New user here stopping in to say thanks for the solution. Several hours wasted until I stumbled across this.
    You can also create an "App Password" for the account. Then use the account name and app password to authenticate. I did this with the latest 1.5 and it worked without making changes to O365.
    3 months later
    Well... having been asked to move the company from Google to 365, I am now facing the same issue as many others.
    OST 1.15.4 (I do need to update, but this should work, right?)
    App password correctly set up, IMAP enabled, POP enabled etc.. but nothing allows authentication to work.
    If I disable authentication for SMTP, then of course it sends, but as expected the result is in the receiver's spam/junk so that's no good.
    I've gone through the options recommended here, and still not working as it should. Just about at my wits end - any further ideas or suggestions before I jump off the ledge?
      KevinTheJedi - Thanks for that... checking it now!
      I assume, however, that if we enable that, we would be deemed a 'short term' user and have it disabled pretty soon (as per the techcommunity article). Enabling it will help to get us running for now, but do you know if OST will include alternative authentication protocols to help us connect it to O365 in the future?
