Same problem here after updating to the newest version.
Is there a solution for this problem?
4 months later
@ceantuco
Nothing yet, still on our todo list/bug sheet. I will mention that development on legacy codebase (current codebase) will be (and is) somewhat slow. We are focusing most of our efforts into the full codebase rewrite.
    5 days later
    I got the same issue after updating to 1.15.4.
    Is there any update please?
    Thank you
    3 months later
    Is there any update about this issue? I upgraded to v1.16 and images are still broken.
    It is also not possible to upload any attachments. They look like they uploaded, but after saving and reopening, there are none.
      intossh
      Not at this time. It’s a much deeper issue that will involve a bit of rewriting due to a previous, major Redactor update. With this being said, the code is open source so if you want to take a crack at it and submit a pull request be our guest.
      2 months later
      Just uncheck "Require login to view any attachments" under Attachments Storage and Settings under System Settings and Preferences and this will take care of it!
        Intellixis
        That’s is not relevant to this thread. This thread is about inline images in FAQ Edit.
        6 months later
        Hi, we'll be upgrading to 1.17, and images are still broken. Any news about the release?
        Thank you
          2 years later
          Hi, I have the same problem, maybe you have a solution? Is the general solution done?
