Hi everyone
Can I upgrade from version 1.14.3 immediately to version 1.15.1? or do I need to upgrade to this path 1.14.3 - > 1.14.4 - > 1.14.5 and only then to version 1.15.1
Yesterday I tried to upgrade from version 1.14.3 immediately to version 1.15.1 and everything broke. It was not possible to open a new ticket, there were also problems in the admin panel, many errors with js files in the browser console. It's good that I made a backup)
You can upgrade from any version 1.6ST+ to current (1.15.1 currently).
That being said you do need to make sure that you meet the pre-requisites for current before you do.
Did you clear your browser cache after upgrading?
Yes, I cleaned the cache. I checked in different browsers, errors fell everywhere. I will try to update again on the test domain.
3 months later
I have the exact same issue. I was able to upgrade to version 1.14.6 with no issue but as soon as I went to go to 1.15 broke on me as well. with a bit of googling you can update mysql and php to 7.2 as suggested.
As soon as you upgrade php to 7.2 you can upgrade to v1.15 with no issues.
