Can any one tell me how to resolve this error. In php.ini is set as 1. still is not working.
same problem here on v1.12.6 (e351ba5) centos 7, I changed cgi.fix_pathinfo in /etc/php.ini to both values 0 and then 1 and the messages still showing with the red exclamation mark, eveen rebooted the server a couple of times and nothing.
cgi.fix_pathinfo isnt needed for non IIS environments.
ntozier i have 2 environment 1 is from OST webhosting. i'm facing this issue. and another one is from my IIS environment. Could you please tell me how to resolve this. Due to this issue i cant able to change the ticket status.
Your screen shot says Apache. If you have more than one web server and the other one tht is having the problem is running IIS, you edit the PHP.ini file and set cgi.fix_pathinfo to 1. Restart IIS.
ntozier cgi.fix_pathinfo=1
make the value to 1 but same error shown
@lokey6475 huh?
3 years later you have made this into a zombie.
cgi.fix isn't needed for Apache servers.
I really doubt that you are running a version that old.
Please read the posting guidelines and start your own thread.
Killing zombie with a head shot
