Server Information
osTicket Version v1.14.2 (cba6035) — Up to date
Web Server Software Apache
MySQL Version 10.1.44
PHP Version 7.1.33
PHP Extensions
imap Used for email fetching
xml XML API
zip Used for ticket and task exporting
PHP Settings
date.timezone UTC
Schema supportticket_76 (localhost)
Schema Signature 4bd47d94b10bd8a6bab35c119dadf41f
Space Used 2.83 MiB
Space for Attachments 0.03 MiB
Timezone EDT (Interpreted as America/New_York)
Plugin not working
@KevinTheJedi Phar extension is enabled.
It is listed under php -m and in osticket info
Did you download the plugin from our website recently or is this an older download of the plugin?
KevinTheJedi Directly from the website
a5fe9b155a57b77cd5f2009aa932f681aa6f1cd05906a8b5712b57efc6c3d094 audit.phar
KevinTheJedi today
Just tested this and it's working correctly. We were making updates to the site today so maybe you caught it at the wrong time. Just re-download it and retest.
KevinTheJedi Still doesn't seem to work.
My issue is with Zend opCache
This is the error I found in my logs with opcache enabled
[01-May-2020 18:26:21 UTC] PHP Warning: array_merge(): Argument #2 is not an array in /home/supportticket/public_html/include/class.plugin.php on line 304
One of the persons suggested to disable opcache:
https://wordpress.org/support/topic/warning-array_merge-argument-2-is-not-an-array-in-load-php-on-lin-63/
Do you know of another fix so I don't have to disable opcache?
Thanks
Try reading this article to see if any of the information helps. I can say that I and a coworker (the author of the plugin) have OPCache installed and enabled and we don’t run into this issue so it's looking like an OPCache configuration issue specific to your environment.
KevinTheJedi Thanks. I found that opcache.validate_permission=0 change gets the plugins to load.
Could you check if your environment has the same setting?
Yes, I can confirm the setting in my environment is the same. Mine is actually commented out but the default is 0
which is Disabled.
