Hey all,
I've had osticket running for about 8 months now. A few months ago started getting DB Error #1064. Have traced to the Dashboard page, as generates an error every time the dashboard is opened. The page is slow to load and the graph never generates. We never use the dashboard page for our setup/use of osticket, but everytime a user clicks it by mistake I get an error email.
Nothing changed, and graph used to work, now just errors. I have moved to a new permanent server from the test setup and same error.
Any help would be awesome ?
osTicket Version v1.12 (a076918)
Web Server Software Apache/2.4.17 (Win32) OpenSSL/1.0.2d PHP/5.6.15
MySQL Version 10.1.9
PHP Version 5.6.15
DB Error #1064
[SELECT A1.topic_id
AS topic_id
, A3.topic
AS topic__topic
, A3.flags
AS topic__flags
, COUNT(CASE WHEN A1.event_id
= 1 THEN 1 END) AS Opened
= 4 THEN 1 END) AS Assigned
= 8 THEN 1 END) AS Overdue
= 2 THEN 1 END) AS Closed
= 3 THEN 1 END) AS Reopened
= 14 THEN 1 END) AS Deleted
FROM ost_thread_event
A1 JOIN ost_thread
A2 ON (A1.thread_id
= A2.id
) LEFT JOIN ost_help_topic
A3 ON (A1.topic_id
= A3.topic_id
) WHERE A1.annulled
= 0 AND A1.timestamp
BETWEEN FROM_UNIXTIME(1557425755) AND FROM_UNIXTIME(1560104155) AND A2.object_type
= 'T' AND A1.dept_id
IN (7) AND A1.topic_id
> 0 AND A1.topic_id
IN () GROUP BY A1.topic_id
] You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ') GROUP BY A1.topic_id
' at line 1
---- Backtrace ----
#0 C:\xampp\htdocs\osticket\include\mysqli.php(199): osTicket->logDBError('DB Error #1064', '[SELECT A1.top...')
topi...', true, true)
#1 C:\xampp\htdocs\osticket\include\class.orm.php(3455): db_query('SELECT A1.
#2 C:\xampp\htdocs\osticket\include\class.orm.php(3502): MySqlExecutor->execute()
#3 C:\xampp\htdocs\osticket\include\class.orm.php(2085): MySqlExecutor->getArray()
#4 C:\xampp\htdocs\osticket\include\class.orm.php(2035): HashArrayIterator->{closure}()
#5 C:\xampp\htdocs\osticket\include\class.orm.php(2014): CallbackSimpleIterator->next()
#6 C:\xampp\htdocs\osticket\include\class.orm.php(2023): CallbackSimpleIterator->rewind()
#7 C:\xampp\htdocs\osticket\include\class.orm.php(1695): CallbackSimpleIterator->valid()
#8 C:\xampp\htdocs\osticket\include\class.orm.php(1705): CachedResultSet->fillTo(2147483647)
#9 C:\xampp\htdocs\osticket\include\class.orm.php(1721): CachedResultSet->asArray()
#10 C:\xampp\htdocs\osticket\include\class.report.php(270): CachedResultSet->getIterator()
#11 C:\xampp\htdocs\osticket\include\staff\dashboard.inc.php(100): OverviewReport->getTabularData('topic')
#12 C:\xampp\htdocs\osticket\scp\dashboard.php(50): require_once('C:\xampp\htdocs...')
#13 {main}
