hello integration with trello works in the current version of osticket?
osticket wicth trello
Never heard of Trello. So I would say no.
Seems to be referring to this plugin: https://github.com/kyleladd/OSTicket-Trello-Plugin
It's showing it's compatible with osTicket v1.10.
I have no idea if that version is compatible.
FYI: Trello is a collaboration board used to manage groups of people doing things.
Then @Mgalejandra would need to talk to the author about that since it is a 3rd party plugin.
Trello looks pretty neat, is it open source?
Hello,
Mgalejandra did you manage to integrate the mentioned plugin? It looks like the source code is approx. 3 years old so I am nore sure if we should use it or not.
@ntozier Yes, Trello is Open Source and implemented by Atlassin (Jira, Confluence)
I chose osticket mainly because of this plugin, but this plugin doesn't work with v1.14. Did anyone of you manage to get it to work?
PipSqueak con la version anterior si me funcionaba el complemento, ahora con esta nueva version de osticket no funciona
Any success on integrating Trello with v1.14?
Hey there! I noticed your post about the integration of osticket with Trello. I know this answer comes a bit late, but I wanted to share something that might be useful to others who might have the same question. I found an article that explains how to export data from Tableau
I'm going to kill this zombie thread with a headshot.
The last post looks like spam to me and doesn't have an actual solution to the question.
