hola buenas tardes , tengo un problema en mi plataforma os , ya que todos los días la debo detener y volver a iniciar para que inicie plataforma de tickets , revisando los logs me reflejan esos errores , alguien me puede ayudar con la solución de este problema ? que son esos errores que reflejan los logs ??
Hello good afternoon, I have a problem in my platform os, since every day I must stop and restart to start the ticket platform, checking the logs reflect those errors, can someone help me with the solution to this problem? What are those errors that reflect the logs?
root@osticket-server:/home/administrator# tail -f /var/log/apache2/error.log
[Mon Apr 22 09:18:15.598448 2019] [core:error] [pid 49930] AH00546: no record of generation 0 of exiting child 10575
[Mon Apr 22 09:18:16.985999 2019] [core:notice] [pid 49930] AH00051: child pid 10583 exit signal Segmentation fault (11), possible coredump in /etc/apache2
[Mon Apr 22 09:18:16.986063 2019] [core:error] [pid 49930] AH00546: no record of generation 0 of exiting child 10583
[Mon Apr 22 09:18:16.986090 2019] [core:notice] [pid 49930] AH00051: child pid 10597 exit signal Segmentation fault (11), possible coredump in /etc/apache2
[Mon Apr 22 09:18:16.986103 2019] [core:error] [pid 49930] AH00546: no record of generation 0 of exiting child 10597
[Mon Apr 22 09:18:16.986128 2019] [core:notice] [pid 49930] AH00051: child pid 10598 exit signal Segmentation fault (11), possible coredump in /etc/apache2
[Mon Apr 22 09:18:16.986141 2019] [core:error] [pid 49930] AH00546: no record of generation 0 of exiting child 10598
[Mon Apr 22 09:18:16.986316 2019] [mpm_prefork:notice] [pid 49930] AH00169: caught SIGTERM, shutting down
[Mon Apr 22 09:18:20.053829 2019] [mpm_prefork:notice] [pid 10666] AH00163: Apache/2.4.34 (Ubuntu) configured -- resuming normal operations
[Mon Apr 22 09:18:20.053901 2019] [core:notice] [pid 10666] AH00094: Command line: '/usr/sbin/apache2'
Looks like your Apache is crashing. You would want to check your codedump to find out why Apache is crashing.
