KevinTheJedi I'm not really sure how to apply the github changes ?.
Unfortunately I can't access the mailserver error logs. Can't find any related errors for apache, php and the database.
Actually got another one these! This time it came from Apples automated e-mail service.
10 days later
KevinTheJedi Seems to be still happening.
I applied the modifications referenced in ticket 4777.
Any chance the email "TO" address might be a factor?
I recently migrated from in house servers to cloud servers ... and the support email address changed.
I set up a forward from the old address to the new address, but it ends up not being the same.
The old address was something like: support@example.com
The new address is similar to support@support.example.com
Sometimes, when a support question is directed to me personally, I use a t-bird plug-in that to redirect the message to the support address.
As a result, the message would be delivered to the support address (via automail.pl) but addressed to something other than the actual support email.
david
@fallingrock
I doubt it but maybe?
It's just extremely weird that another forum user has issues with empty bodies until he switched to fetching (from piping) and now it's all good. For you guys it's quite the opposite. Fetching works for all providers in my testing so I'm not sure what the difference is between your setup and mine. Any additional information will be helpful.
4 months later
Is anything new about this issue ? We have similar problems with emails fetching and empty body.
osTicket Version v1.12 (a076918) — Up to date
Web Server Software Apache/2.4.25 (Debian)
MySQL Version 10.3.15
PHP Version 7.1.27-1+020190307202204.14+stretch1.gbp7163d5
PHP Extensions
imap Used for email fetching
xml XML API
PHP Settings
date.timezone Setting default timezone is highly recommended
Schema osticket (localhost)
Schema Signature 00c949a623b82848baaf3480b51307e3
Space Used 107.88 MiB
Space for Attachments 85.52 MiB
Timezone CEST (Interpreted as Europe/Berlin)
10 days later
We are also facing the issue with empty body when fetching emails from Exchange via iMap unless they are plain text emails which the majority of email are not. We have tested every solution suggestion we have found here without success.
Server Information from out test server (we are yet to put it into production):
osTicket Version v1.12.2 (a5d898b) — Up to date
Web Server Software nginx/1.14.2
MySQL Version 5.7.27
PHP Version 7.2.18
PHP Extensions
xml XML API
PHP Settings
date.timezone UTC
Schema osticket (mysql)
Space Used 2.94 MiB
Space for Attachments 0.03 MiB
Timezone UTC
    7 days later
    MagnusS We have the same issue. Work for Gmail but not outlook mail
    5 days later
    I have been setting up osticket for the first time and ran into the empty body issue as well using imap fetch + exchange.
    I tried all the different fixes but the following changed worked for me, on the exchange mailbox with imap enabled go into properties of imap under mailbox features and uncheck "use protocol default" and switch the drop down to HTML and alternative text. After making this change emailed tickets work perfectly.
    Hope this helps
      7 months later
      6 months later
      I do have the same problem here. It seems to happen with certain HTML e-mail content.
      Any solution?
