When going into a ticket, and printing via the print button we get the print ticket options, select paper size and then get a This page isn’t working osticket.website is currently unable to handle this request.
HTTP ERROR 500
This has only happend since the upgrade to 1.11
Tested everything bar the printing on out test system and have checked and can replicate in there as well
All user affected...
Environment details?
PHP errors?
I am unable to replicate this issue.
Environment is
osTicket Version v1.11 (d4e240b) — Up to date
Web Server Software Microsoft-IIS/8.0
MySQL Version 5.5.45
PHP Version 7.0.27
There is nothing in the PHP logs either, previous to the upgrade, running 1.10 in the same environment, printing worked..
Just recreated the error, and checked the php error log straight away, and no error, but the error on the page is still
HTTP ERROR 500
@DaveA
Run this in PHP and see if it returns an output:
echo sys_get_temp_dir();
    KevinTheJedi Hi Kevin
    Thanks for the reply, Not sure if I did this right, as I am running php on windows and IIS, but opened an interactive php promp and ran the above and nothing
    I ran php.exe -a is this the right way to do this?
    Thanks for your help
    Dave
    create a tmp.php file.
    put <?php echo sys_get_temp_dir(); ?> in it.
    at the cmd line type php tmp.php
    @DaveA
    If you do as @ntozier said and you still get an empty output then this is the issue. We use a third party PDF generator called mPDF and mPDF needs a temporary directory to put things whilst building the PDF. If your system has no temporary directory this will fail. In order for this to work you must configure PHP with a temporary directory. Almost 99% of the time there is already a temp directory configured so not sure if you guys deleted yours, changed permissions on yours, etc. but all you need to do is create a temp dir and configure PHP to use this as the temp directory.
    side note: By default PHP ini has a tmp dir set last time I checked.
    There is a temp directory, and just to eliminate any potential permissions issue, I went onto out Windows IIS Server (logged in as domain admin), and opend the website on there, and tried to print a ticket, and still got a 500 error.
    Have checked the folder, and as an Admin on the server itself no reason that permissions should be an issue.
    Can't see what has changed as we just did a straight upgrade from 1.10 and ticket printing was fine then....it was the one thing I didn't test on the system before upgrading the live one...
    Other people who don't have the issue, are any of them running a wimp stack? (No not a wamp, we run a wimp windows, iis, MySQL, php)
    Any ideas and all your help so far greatly appreciated...
    Dave
    Yes. I am run IIS 8.5 with PHP 7.2 and I do not have a problem with printing.
    It does seem to take a little longer than it did previously though (but that might be just my perception).
    Should point out, that I also ran this, as in the windows environment to ensure the files were not listed as blocked
    dir -Path [directory path] -Recurse | Unblock-File
    Thanks for everyone's helps o far, sadly no resolution yet....
    a month later
    the same problem .
    Clean installation v1.11 , only in English with PHP 5.6 or 7 SQL 5.6.36 and PDF does not work, open page with error 500 but with OsTicket 1.10 everything works fine. Solutions?
    UP
      absolute Still the same issue and have yet to find a resolution
      Hi Kevin,
      my error:
      Warning: unlink(/tmp/sess_pu4rlc1eoq3s580adc53mjsa77): Operation not permitted in /home/www/web234/html/aftersalesservices/include/mpdf/vendor/mpdf/mpdf/src/Cache.php on line 95
      Warning: unlink(/tmp/sess_5243a79468c4d7d69ae74f8aa9f7778c): Operation not permitted in /home/www/web234/html/aftersalesservices/include/mpdf/vendor/mpdf/mpdf/src/Cache.php on line 95
      Warning: unlink(/tmp/tmp.rbuMe23399): Operation not permitted in /home/www/web234/html/aftersalesservices/include/mpdf/vendor/mpdf/mpdf/src/Cache.php on line 95
      Warning: unlink(/tmp/sess_b565e4e63284fbf77adad191d7c87749): Operation not permitted in /home/www/web234/html/aftersalesservices/include/mpdf/vendor/mpdf/mpdf/src/Cache.php on line 95
      Thanks
      unlink() is a PHP directive that deletes a file.
      sess_* is a session file.
      operation not permitted means that either PHP does not have permissions to remove the file it created [this could either be the folder that it resides in, the file permissions itself, or the ownership of the file], or you are some how blocking the directive from being run.
        ntozier
        Thanks Ntozier.
        With OsTicket 10.1 and 10.5, PDF printing works. With OsTicket 11.1 it does not work. The php temp directory of my server is called phptemp not tmp. Can this be the problem? I can't edit that folder. Can I change the location of this temporary folder somewhere?
        Thank you.
        Please check the php.ini file to see what your tmp folder is actually called and where it is located.
        Either mpdf is using the wrong tmp folder or php is...
        I had the same issue, for me it seemed to be the "open_basedir" restriction, even if I had the Php /tmp/ dir writeable and in my Php.ini for the specific site,
        Perhaps not the solution, but when I set "open_basedir none" it works, although I really do not like this setting from a Security Point of View....
        But it is a step forward perhaps, in troubleshooting ?
        Edit:
        When setting the open_base paths back and have the correct dirs setup and permissions, the 500 Internal Error comes back, when trying to print..
        @absolute
        Change the owner of the directory "/path/to/osticket/include/mpdf/vendor/mpdf/mpdf/tmp/" to the webserver user/group; this should resolve the permissions issue. I had to run the following command:
        $ chown apache:apache /path/to/osticket/include/mpdf/vendor/mpdf/mpdf/tmp/
        This may differ for your server so please lookup the right way to change ownerships on your server.
        In tandem with this, you will need to apply these pull requests:
        - https://github.com/osTicket/osTicket/pull/4815
        - https://github.com/osTicket/osTicket/pull/4814
        After all this you should be able to print PDF no problem.
          10 days later
          Hi Kevin and thanks for your assistance.
          I made the two fixes you reported and my Host manager told me that the permissions are correct. I'm attaching JPGs of permits, are they correct?
          I have clean installation but it doesn't work, the PDF doesn't print, thanks.
          @absolute
          Then you should be receiving an error in your Apache/PHP error logs. We need these errors for further assistance.
            6 days later
            osticket uses the system temp folder for generating the pdf and not mpdf/tmp. So check what sys_get_temp_dir() returns for you and set the permissions for osticket on that folder, or use the 'sys_temp_dir' ini directive to set it to a folder that is writable.
            a month later
            Hi Kevin, mi log error:
            [Tue May 07 17:50:27 2019] [error] [client 89.97.217.102] PHP Fatal error: Uncaught RuntimeException: SplFileInfo::isFile(): open_basedir restriction in effect. File(/tmp/mysql.sock) is not within the allowed path(s): (/home/www/:/tmp:/usr/local/php7/lib/php/) in /home/www/web234/html/test/include/mpdf/vendor/mpdf/mpdf/src/Cache.php:92, referer: http://test.absyachts.com/scp/tickets.php?id=87
            [Tue May 07 17:50:27 2019] [error] [client 89.97.217.102] Stack trace:, referer: http://test.absyachts.com/scp/tickets.php?id=87
            [Tue May 07 17:50:27 2019] [error] [client 89.97.217.102] #0 /home/www/web234/html/test/include/mpdf/vendor/mpdf/mpdf/src/Cache.php(92): SplFileInfo->isFile(), referer: http://test.absyachts.com/scp/tickets.php?id=87
            [Tue May 07 17:50:27 2019] [error] [client 89.97.217.102] #1 /home/www/web234/html/test/include/mpdf/vendor/mpdf/mpdf/src/Mpdf.php(9392): Mpdf\Cache->clearOld(), referer: http://test.absyachts.com/scp/tickets.php?id=87
            [Tue May 07 17:50:27 2019] [error] [client 89.97.217.102] #2 /home/www/web234/html/test/include/class.pdf.php(51): Mpdf\Mpdf->Output('Ticket-ABS45483...', 'S'), referer: http://test.absyachts.com/scp/tickets.php?id=87
            [Tue May 07 17:50:27 2019] [error] [client 89.97.217.102] #3 /home/www/web234/html/test/include/class.ticket.php(3125): mPDFWithLocalImages->output('Ticket-ABS45483...', 'S'), referer: http://test.absyachts.com/scp/tickets.php?id=87
            [Tue May 07 17:50:27 2019] [error] [client 89.97.217.102] #4 /home/www/web234/html/test/scp/tickets.php(498): Ticket->pdfExport('A4', '0'), referer: http://test.absyachts.com/scp/tickets.php?id=87
            [Tue May 07 17:50:27 2019] [error] [client 89.97.217.102] #5 {main}, referer: http://test.absyachts.com/scp/tickets.php?id=87
            [Tue May 07 17:50:27 2019] [error] [client 89.97.217.102] thrown in /home/www/web234/html/test/include/mpdf/vendor/mpdf/mpdf/src/Cache.php on line 92, referer: http://test.absyachts.com/scp/tickets.php?id=87
            [Tue May 07 17:50:32 2019] [error] [client 89.97.217.102] PHP Warning: Invalid argument supplied for foreach() in /home/www/web234/html/test/include/staff/templates/queue-tickets.tmpl.php on line 393, referer: http://test.absyachts.com/scp/tickets.php?id=87
            [Tue May 07 17:50:37 2019] [error] [client 89.97.217.102] PHP Fatal error: Uncaught RuntimeException: SplFileInfo::isFile(): open_basedir restriction in effect. File(/tmp/mysql.sock) is not within the allowed path(s): (/home/www/:/tmp:/usr/local/php7/lib/php/) in /home/www/web234/html/test/include/mpdf/vendor/mpdf/mpdf/src/Cache.php:92, referer: http://test.absyachts.com/scp/tickets.php?id=87
            [Tue May 07 17:50:37 2019] [error] [client 89.97.217.102] Stack trace:, referer: http://test.absyachts.com/scp/tickets.php?id=87
            [Tue May 07 17:50:37 2019] [error] [client 89.97.217.102] #0 /home/www/web234/html/test/include/mpdf/vendor/mpdf/mpdf/src/Cache.php(92): SplFileInfo->isFile(), referer: http://test.absyachts.com/scp/tickets.php?id=87
            [Tue May 07 17:50:37 2019] [error] [client 89.97.217.102] #1 /home/www/web234/html/test/include/mpdf/vendor/mpdf/mpdf/src/Mpdf.php(9392): Mpdf\Cache->clearOld(), referer: http://test.absyachts.com/scp/tickets.php?id=87
            [Tue May 07 17:50:37 2019] [error] [client 89.97.217.102] #2 /home/www/web234/html/test/include/class.pdf.php(51): Mpdf\Mpdf->Output('Ticket-ABS45483...', 'S'), referer: http://test.absyachts.com/scp/tickets.php?id=87
            [Tue May 07 17:50:37 2019] [error] [client 89.97.217.102] #3 /home/www/web234/html/test/include/class.ticket.php(3125): mPDFWithLocalImages->output('Ticket-ABS45483...', 'S'), referer: http://test.absyachts.com/scp/tickets.php?id=87
            [Tue May 07 17:50:37 2019] [error] [client 89.97.217.102] #4 /home/www/web234/html/test/scp/tickets.php(498): Ticket->pdfExport('A4', '1'), referer: http://test.absyachts.com/scp/tickets.php?id=87
            [Tue May 07 17:50:37 2019] [error] [client 89.97.217.102] #5 {main}, referer: http://test.absyachts.com/scp/tickets.php?id=87
            [Tue May 07 17:50:37 2019] [error] [client 89.97.217.102] thrown in /home/www/web234/html/test/include/mpdf/vendor/mpdf/mpdf/src/Cache.php on line 92, referer: http://test.absyachts.com/scp/tickets.php?id=87
            If I comment the function as below it deletes the session links in / tmp, work! Can I leave it like this or write without deleting it in the / tmp?
            Thank
            /** @var \DirectoryIterator $item */
            	//foreach ($iterator as $item) {
            // if (!$item->isDot()
            // && $item->isFile()
            // && !$this->isDotFile($item)
            // && $this->isOld($item)) {
            // unlink($item->getPathname());
            2 months later
            Hi I am having the same problem and cannot exactly work out why.
            I am using,
            Os tickets version 1.12
            PHP Version 7.2.19
            Cent OS 6.10
            MySQL version 5.1.73
            My PHP error log displays the following:
            [Thu Jun 27 13:06:14 2019] [warn] [client 213.123.193.35] mod_fcgid: stderr: PHP Fatal error: Uncaught RuntimeException: SplFileInfo::isFile(): open_basedir restriction in effect. File(/tmp/plesk_17.8.11_installation.log) is not within the allowed path(s): (/var/www/vhosts/website.net/:/tmp/) in /var/www/vhosts/website.net/support/include/mpdf/vendor/mpdf/mpdf/src/Cache.php:92, referer: https://support.website.net/scp/tickets.php?id=2352
            [Thu Jun 27 13:06:14 2019] [warn] [client 213.123.193.35] mod_fcgid: stderr: Stack trace:, referer: https://support.website.net/scp/tickets.php?id=2352
            [Thu Jun 27 13:06:14 2019] [warn] [client 213.123.193.35] mod_fcgid: stderr: #0 /var/www/vhosts/website.net/support/include/mpdf/vendor/mpdf/mpdf/src/Cache.php(92): SplFileInfo->isFile(), referer: https://support.website.net/scp/tickets.php?id=2352
            [Thu Jun 27 13:06:14 2019] [warn] [client 213.123.193.35] mod_fcgid: stderr: #1 /var/www/vhosts/website.net/support/include/mpdf/vendor/mpdf/mpdf/src/Mpdf.php(9392): Mpdf\Cache->clearOld(), referer: https://support.website.net/scp/tickets.php?id=2352
            [Thu Jun 27 13:06:14 2019] [warn] [client 213.123.193.35] mod_fcgid: stderr: #2 /var/www/vhosts/website.net/support/include/class.pdf.php(51): Mpdf\Mpdf->Output('Ticket-666647.p...', 'S'), referer: https://support.website.net/scp/tickets.php?id=2352
            [Thu Jun 27 13:06:14 2019] [warn] [client 213.123.193.35] mod_fcgid: stderr: #3 /var/www/vhosts/website.net/support/include/class.ticket.php(3125): mPDFWithLocalImages->output('Ticket-666647.p...', 'S'), referer: https://support.website.net/scp/tickets.php?id=2352
            [Thu Jun 27 13:06:14 2019] [warn] [client 213.123.193.35] mod_fcgid: stderr: #4 /var/www/vhosts/website.net/support/scp/tickets.php(498): Ticket->pdfExport('A4', '0'), referer: https://support.website.net/scp/tickets.php?id=2352
            [Thu Jun 27 13:06:14 2019] [warn] [client 213.123.193.35] mod_fcgid: stderr: #5 {main}, referer: https://support.website.net/scp/tickets.php?id=2352
            [Thu Jun 27 13:06:14 2019] [warn] [client 213.123.193.35] mod_fcgid: stderr: thrown in /var/www/vhosts/website.net/support/include/mpdf/vendor/mpdf/mpdf/src/Cache.php on line 92, referer: https://support.website.net/scp/tickets.php?id=2352
            Please advise and provide direction.
              macsoluk [Thu Jun 27 13:06:14 2019] [warn] [client 213.123.193.35] mod_fcgid: stderr: PHP Fatal error: Uncaught RuntimeException: SplFileInfo::isFile(): open_basedir restriction in effect. File(/tmp/plesk_17.8.11_installation.log) is not within the allowed path(s): (/var/www/vhosts/website.net/:/tmp/) in /var/www/vhosts/website.net/support/include/mpdf/vendor/mpdf/mpdf/src/Cache.php:92, referer: https://support.website.net/scp/tickets.php?id=2352
              php open basedir appears to be preventing stuff from running properly.
              I would recommend that you fix that first. See if that solves the issue.
              If it does not then we can look at the new error.
              15 days later
              Hi there,
              similar issue here. Upgraded to 1.12 from 1.10. Printing worked prior to the upgrade, no other system changes made. MYSQL PHP and IIS are all exactly the same as they were prior to the upgrade. PHP error log does not show anything when this error happens.
              Server Information
              osTicket Version v1.12 (a076918) — Up to date
              Web Server Software Microsoft-IIS/10.0
              MySQL Version 8.0.14
              PHP Version 7.0.33
              @cruzzlie please open your own thread. Please provide all the information listed in the posting guidelines.
