Hi there,When I want to post a reply, in the answer part, how do I change the options?Versión osTicket
v1.10.1 (9ae093d)
Servidor del Software Web
Apache/2.4.33 (Win32) OpenSSL/1.0.2o PHP/5.6.36
Versión MySQL
10.1.32
Versión PHP
5.6.36
I'm sorry but I'm not sure what it is that you are trying to ask.
I'm sorry, I did my question wrong, what I needed was to erase the premade replies jejejjejejeje  , well, I solved it thank you very much
You might want to post what you did to solve your issue so that if someone else has a similar question they can find your answer.
