In osticket we have a team X (basicaly 3rd-Level-Support) which stretches over several Departments.Usually the workflow is like this: Ticket comes in and is assigned to a supporter. Supporter investigates the issue and sometimes comes to the conclusion that he needs in-depth technical help. He then assigns the ticket to the team X . The ticket stays in the Support department since it's technically still a support case that needs further investigation by team X, the supporter is still responsible for communication with the client.Problem is that the ticket does not show under MyTickets for Team X because it is at the same time assigned to the original agent (also cant be unassigned easily), so it usually takes Team X a while to see that there is a Ticket that needs their attention. Is it possible to make these Tickets appear under "my Ticktes" for Team X like it would if it is only assigned to the team and has no agent?
