If that is a name in the system, yes. It was mainly developed for staff/agents, so if you have single-word names it works best, like @[deleted] would work, however, if there was spaces in the name, it won't. But, you can use a ".", so, @[deleted] would work to match an agent. The mention part is pretty cool as well, if you wanted to bring in another agent without adding them, you can use #pradeep.surname or #pradeep1987oct22, they get an email notification telling them that they were mentioned (configurable in config).For it to add Users as collaborators, we kinda have to know about them in advance, which works well for established systems with lots of users already. You can @[deleted] and have it find them by the domain prefix, if that domain is added to the config.. actually, it doesn't work that well for Users.. they dont' have usernames! hmm. If you'd like an extension/adaptation or change to it mate, just make an issue for me on github and I'll get it working: https://github.com/clonemeagain/osticket-plugin-mentioner/issues/new I'm thinking an organisation filter might help, so users from an organisation could @[deleted] and have the first John in their organisation be added as a collaborator.  You can see the problem with that being global though. A lot of people have the same names. Even Agents have many duplicates in our system. That's why it does email matching as well, @[deleted] or @[deleted] etc. But the firstname.surname match only works for staff at the moment.
    Hi Pradeep, John and Jsmith! :-) lol The only one that didn't match here was @[deleted]
    @[deleted], just an FYIWe are testing the mentioner plugin for our agents, and I noticed that I received a mention alert when someone typed #1 in their message to the user because my agent ID number is 1 in the database.Thanks again btdubs for all the time you put into the forwarder plugin you are working on as well.
    Woah, that's both cool and bad. Is it a bug or a hidden feature? Lol I'm pretty sure bug as it's not intended.
    Found the culprit though, Staff: ( $name )
    If name is a number, then it will return the id matched agent. That should be an easy fix, I'll get it done tomorrow.
    Patched https://github.com/clonemeagain/osticket-plugin-mentioner/issues/6
    a month later
    Hi @[deleted] ,Is it possible to use email address say abc@abc.com (neither a staff nor a user) instead of a name , what if we need to mention/ add collaborator who is new to our Osticket system.
    Wouldn't that add any address?.. including in signatures. Could be bad.
    You can always use the "add collaborator" function while viewing a ticket to add someone, or cc'ing them on the original email.
    Hmm, you wouldn't want it to be a spam vector: someone could send a message with white text listing hundreds of addresses and they'd all get spammed as if by you..
    But, if you wanted a patch to enable it, it's certainly possible, just ill advised..
    hi @[deleted],What if only staff be able to add email address as collaborator.Totally agree, with spam thing.
    That's already available via the "add collaborator" staff interface. Isn't it? Maybe I'm missing something.
    5 years later
    Hello Grizly,
    I have been testing your useful plugin and i didn't manage to find out why the collaborators does not receive notifications when the ticket it is created nor when new message on ticket is placed.
    Hope you can help me on that.
    I am currently on osTicket Version v1.15.7
    Thank you!
