I totally understand your recommendation. The 'https://support.mydomain.com/osticket/upload/' format for the Helpdesk Url is the certainly the best practice. It is just that, through my shot in the dark tinkering, I found that appending the extra 'view.php' part seems to resolve the issue where the FQDN gets changed to the internal IP. I really like the use of the %{url} that you suggest. I updated my email templates and found a separate issue. Now the text of the link is the Helpdesk Url that is specified in the "ost_config" table (in my case, the link currently includes the 'view.php' part, however when I hover over or click the link it takes me to 'https://support.mydomain.com/osticket/upload/' I traced the problem to the embedded link. i.e. When I click literally on the "%{url}" when editing the template, I get an option to "Edit" or "Unlink" the link. Since I want the link to also be "%{url}" I set the URL to match the Text. Now both are set to "%{url}" (without the quotes). However, when I click "Edit" to save the change to the URL field, it converts to %%7Burl%7D. I can't seem to win for losing. I guess I'll change the URL link value to https://support.mydomain.com/osticket/upload/view.php
