Hello, we are successfully using osTicket in one installation without a central directory. Currently we have to deploy one more instance of it, but the strong requirement is to interface it to an existing LDAP user base. So we proceeded with a new install and addition of the "auth-ldap" plugin.All the prerequisites were preinstalled, the installation went on without any glitches, and in the end "auth-ldap.phar" plugin was added. These are the technical details of our installation:OS: Centos 7 (1611)Mysql: mysql-community-server-5.6.35-2.el7.x86_64PHP: php-5.4.16-42.el7.x86_64osTicket: 1.10auth-ldap.phar plugin: 0.6.3LDAP server: openldap-2.4.40-13.el7.x86_64 (no anon bind, ldaps with K5 backend responding at port 636). This server perfecly works with SSSD on many nodes and, among other uses, provides authentication for a Dokuwiki web site running on the same host where osTicket was just installed.This is how our typical user is defined inside LDAP:# LDAPv3# base <dc=example,dc=com> (default) with scope subtree# filter: uid=testus# requesting: ALL## testus, Users, example.comdn: uid=testus,ou=Users,dc=example,dc=comobjectClass: topobjectClass: inetOrgPersonobjectClass: posixAccountuid: testuscn: Andysn: AppledisplayName: Andy AppleuidNumber: 16055gidNumber: 21003loginShell: /bin/tcshhomeDirectory: /home/testustelephoneNumber: 008189934mail: andy.apple@example.comThe installation and enablement of auth-ldap.phar went smoothly, and we were able to obtain the green message after configuring the plugin. To get this green message, we had to specify "ldaps://ldap.example.com" in place of "ldap.example.com". The binddn and its password worked without problems. So far so good..Finally, I've tried to login into osTicket usting the existing LDAP user and its password. This did not work and the web server reported this error: PHP Fatal error: Call to a member function bind() on a non-object in phar:///var/www/html/tt/include/plugins/auth-ldap.phar/authentication.php on line 220, referer: https://ticket.example.com/login.phpDigging a bit, I've discovered that this problem was occuring in the "getConnection" function inside "authentication.php", specifically some of "defaults" array entries were undefined before executing "bind" within this fragment of code: foreach ($this->getServers() as $s) { $params = $defaults + $s; $c = new Net_LDAP2($params); $r = $c->bind(); if (!PEAR:($r)) { $connection = $c; return $c; } }So I have set these:$defaults = 636;$defaults = false;$defaults = 'uid=bindus,ou=Users,dc=example,dc=com';$defaults = 'bindpassword';$defaults = 'dc=example,dc=com';Then I added into $defaults 'LDAP_OPT_PROTOCOL_VERSION' => 3(this setting is successfully used for Dokuwiki authentication on the same box).After that, the error message did not appear anymore, and the authentication process went much further. But the user was anyway not accepted ("Access denied" message). I then redfined the RFC-2307 schema as follows: // A general approach for RFC-2307 '2307' => array( 'user' => array( 'filter' => '(objectClass=posixAccount)', 'first' => 'cn', 'last' => 'sn', 'full' => array('displayName'), 'email' => 'mail', 'phone' => 'telephoneNumber', 'mobile' => 'telephoneNumber', 'username' => 'uid', 'dn' => 'uid={username},{search_base}', 'search' => '(&(objectClass=posixAccount)(|(uid={q}*)))', 'lookup' => '(&(objectClass=posixAccount)({attr}={q}))', ), ),And then traced the issue to this point at function "authenticate": if (!PEAR:($r)) return $this->lookupAndSync($username, $dn);This led me to the "lookup" function call inside lookupAndSync: if (!($info = $this->lookup($dn, false))) return;Which finally ported me to the search call defined in the "include/Net/LDAP2/Search.php" $r = $c->search($lookup_dn, '(objectClass=*)', $opts); if (PEAR:($r) || !$r->count()) return null; So this search call ended without finding the user inside LDAP (but the bind went well with his password).===========================================To conclude, it seems that everything is almost working, but, most probably, I must have made some mistake with the schema definition. I will dig it further, but any hint/help at this stage would be highly appreciated. We are very much impressed with osTicket (use it at another organization), but in our current setup we absolutely need to interface it with LDAP. Thanks ahead for your help, and best regards!Andy.
