Hi do i need any specific extensions to install this?
Im using the lastest version of WampServer that ships with:
PHP 5.2.6
MySQL 5.0.51b
Apache 2.2.8
Every time i fill in the installation details i get reverted back to the same screen, no errors are show, no database is created.
Thanks for your help
Craig
Same problem
I had the same problem. I had short_open_tag disabled in php.ini. After I enabled this and restarted Apache my problem was solved. If you can not change php.ini the same effect could be achived by creating a .htaccess-file but I did not got that working.
See also: (http://osticket.com/forums/showthread.php?t=673).
Regards,
Thomas.
15 days later
I am new to this forum and osticket,
I am having the same issue, I have added .htaccess to root and I have also enabled short_open_tag = On but I still cannot get passed the install screen.
Any help much appreciated.
Thanks Darren
2 months later
PHP 5.2.6
MySQL 5.0.51b
Apache 2.2.8
Craig
Be sure that the php5-mysql module is installed or pdo_mysqli. You can check by adding the following to a .php file somewhere and viewing it:
<?php phpinfo(); ?>
Search for "mysql." You can also us this method to see if php short tags is enabled.
Same here
Craig,
Turns out I had the same issue. I had short_open_tag = on in my php.ini, but I *didn't* have the mysql module for PHP installed on my system. On CentOS, I ran the following command to solve my issue:
yum install php-mysql
Restarted apache and it worked just fine.
Thanks,
blunted1
Criag
what os are u using?
irperera
4 months later
Craig,
Thanks,
blunted1
This is what I was missing!
Installed php-mysql and restarted httpd service. All set now! Thanks!
