the latest beta RC is Peters last addition with more ticket statusincluded in this ? git clone https://github.com/osTicket/osTicket-1.8 . ?
I would think that you would need to use: https://github.com/osTicket/osTicket-1.8/tree/v1.9-rcbut then I don't use git/github muchAlso I should note that you should not be running this version in a production environment at this time.
Oh and this just happened: https://github.com/osTicket/osTicket-1.8/pull/1159
nah i just wanna play around with it figured the more o test the beta the more ill learn and since i use osticket for something complete diffrent then a ticket system and mine is heavly modified to fit my needs i need to hack the code myself to get more "ticket status" option when its done.Have i understood right that the new "ticket status" will be that you can add how many ticket statuses you need by yourselfs ?
Q: Have i understood right that the new "ticket status" will be that you can add how many ticket statuses you need by yourselfs ?A: That is my understanding.
