@[deleted] the mod author rowlandan25 has not posted a version for 1.9 yet.
Hi there. Im currently on version 1.9.2 .. And i found your topic buat it was kind of outdated.. version 1.8.1 ?? And rowlandan25 last reply on here was nearly 2months ago in May. Is the development already stop? Im afraid i will need this ticket status mod very badly! T_T
bump
Good morning everyone,First off, I would like to apologize for not being active the past couple of months. Unfortunately work is busiest for me during the summer and I have not had the time to sit down and get the newest version of ticket status out. I am going to begin development again and get that out soon! When I do, I will start a new discussion in the 1.9 forums and post a link to that discussion here.Once I get the update done, I will be looking for some testers to so that I can find any issues with it!Andy
Andy
thank you rowland. look forward to contribute on your thread :)
Hey everyone,I create a new thread for the 1.9.3 version of this mod. Take a look: http://forum.osticket.com/d/discussion//add-statuses-to-your-tickets
@rowlandan25 Just wondering if this is now included in release 1.9.4? If so, I don't seem to see the status in the "open ticket" listing. Is there anything I'm missing? How can someone on version 1.9.4 achieve the "Status" view of open tickets?Thanks for the reply.
same for me! ver 1.9.4 (c18eac4) plugin(Language (Portuguese))only appear total openticket(0) close(0).tks
i've got it working on 1.9.4there's quite a few differences in there. i made no changes to any files which don't already exist in 1.9.4, just uploaded those files to the relevent folder.for files that already exist, i run a diff on the mod files, comparing them to the unmodified 1.9.3 files to find out what the actual mods were.and copied them into the 1.9.4 files, making changes to match the new syntax where necessary, it's obvious what these changes need to be when the mods are pasted in.the big problem was the changes in table/field names in 1.9.4basically change: .' ,status.statusName as statName, status.colorBG as bg, status.colorFG as fg, status.colorBD as bd';to: .' ,stat.statusName as statName, stat.colorBG as bg, stat.colorFG as fg, stat.colorBD as bd';and ' LEFT JOIN '.MOD_STATUS.' status ON msa.statusId=status.id';to ' LEFT JOIN '.MOD_STATUS.' stat ON msa.statusId=stat.id';in /include/staff/tickets.inc.php
I am working on upgrading the mod to version 1.9.4 and hope to have a working version out by the end of the week.
is there any reason for holding onto the previous statuses? ie isActive = 0 in mod_status_assignmentsit would make the table very large quite quickly, especially on a busy helpdesk.i would suggest when updating the ticket status in that table, it then deletes any rows where isActive = 0.i've found that leaving them in there means it displays different statuses for a ticket when ordering by tstatus ASC than it does ordering by tstatus DESC.
I am already working to remove this table, and will be removed in the next update :) It was meant to be temporary till I added an internal note for status changes.
cool.i have a couple of suggestions, some of which i'm sure you're already planning, or have at least considered.having statuses like: scheduled, client/customer update. where scheduled using the due date, which i believe (not tested it yet) sets out an stale ticket alert, and sets the ticket to overdue using it's own ticket status. i'd like to see the mod ticket status (tstatus) get changed to overdue at the same time. i'd like to see this happen when the SLA period expires as well. (it may already, as i said, i've not tested it yet)when a customer responds, a new message alert is sent out, i'd like tstatus to change the tickets state to client/customer update. so basically it responds to events, rather than having to manually change the status.probably simple enough stuff, just not had a chance to look at the code for it, and i'd imagine most people would want it.
Build 1007 (which I never got to the point to release before 1.9.4 came out) has started those suggestions. I have pre-defined locations (when a ticket is opened, when a ticket is assigned, and when a ticket is reopened) that the status is updated. I am looking to expand on those, and your options are great places to start. The overdue via SLA period should not be difficult to do as I just need to find where this is handled. Having a scheduled status also should not be too difficult, again, I just need to find where it is handled.I looked into doing the responses and that one is more tricky. I was having difficulties determining the response type between an agent posting a response and a client/customer posting a response. I just having to look some more and see if there is an easy fix.Thanks for the suggestions.
Build 1008 of my module is ready to go (you can get it here: https://github.com/rowlandan25/osTicket-Modules/releases/tag/1008).If
you run into any issues, please be sure to post them on GitHub so I can
take a look. I have tested this pack on a fresh osTicket v1.9.4
install and I have also tried it on an osTicket v1.9.3 install with my
Build 1006 module pack. Both of them worked perfectly. Please, make
sure that you create a copy of your web directory and database before
installing any module.If you would like to see anything added, please feel free to submit that on GitHub as well and I will look into adding it.Enjoy!Andy
Hi this is not working for us, it shows the ticket status in now but the colors will not change no matter what they are set to and in the custom list properties the variables are all set to 15 which conflicts.
Hi Wizard123,Thanks for the post. This issue has been reported on GitHub and I already have a fix for it. I am finishing up fixing a couple more bugs and then I will have another update posted this morning.Andy
Great thank you very much.
Hi, I have added two custom fields in the ticket. In the Ticket.cdata these fields are called RMS and RIS and I would see them on the main page of the agent (2 new coloumn):scp / index.phpHow do?I have osticket 1.9.4
Hi, I'm trying to display a column in the ticket portion of the agent panel that shows the respective Department for each ticket. You can view the screen in this image: I posted something about it and I was directed to this forum. I have downloaded the Mod and it seems to be displaying a Status bar, however I'd like to know how to change it so that it displays Departments instead. I do not feel comfortable editing the code itself since I don't know php, I'm just trying to set up the service.Currently, this is what I see when viewing my "Modules" :If I could receive some either managing the Mod or editing the code so that I can add a "Departments" column, that would be hugely appreciated. Thanks! :)
