I would not recommend running this mod on 1.9.+ since the feature is actively being worked on by the devs and might even make the next release.
a year later
hey guys,in have not the "newticket.inc.php" i changed it at the "tickets.inc.php"i add the value in the database "ost_tickets".osticket say " * Invalid source given - Monitoring"has anyone a idea?
This thread is from 2011.What version are you running?
ost 1.9.12 on ms win2012, iis8,5 and php 5.6.14blank
I don't see anything wrong with what you have done.
With these settings, it should go .... yes or?
5 days later
The condiation is "!in_array(strtolower" so you i write "monitoring" with an small "m". Then it will work,
2 years later
hi has anyone tested this working on v1.10.1 i want to add a few new ticket source fields as well ?
7 months later
Hi, I just tried it and it works! but when I do an advanced search and select the source, I do not see the ones I added. Any ideas????
This thread is from 2011... for version 1.6.  You are bound to run into difficulty with advanced search since it was updated multiple times between 1.6 and current.  ost_ticket.source is an enum.  Which means you likely have to change the table itself.
