czarek
  1. Upgrade to a supported version (either v1.17.5 or v1.18.1).
  2. Try changing your Apache from PREFORK to FAST_CGI.
    ad.2 i'm already using FAST_CGI.
    I made some tests and figured out, that attachements are not apearing, when i reply to "closed" or "resolved" tickets.
    After reopened and reply, they show up correctly.
    I'll try to upgrade to current version today
    9 days later
    Seems like upgrade to 1.18.1 resolved the problem
    7 days later
    In long-term tests with more agents than me, problems seems to appear in random situations.
    Another problem is waiting to "all changes saved". Is there any reason why it takes so long?
    Current version is 1.18.1
      czarek
      You’ll have to explain those random situations and be able to replicate them or at the very least have related errors referencing the issue for us to further assist.
      Drafts save every 5 seconds of inactivity. The length of time to save drafts depends mainly on network speed, server speed, and databas speed.
      At the bottom, You see the log of a single try to attach pdf file:
      192.168.55.12 - - [18/Jul/2024:05:26:21 +0000] "GET /scp/tickets.php?id=14722&_pjax=%23pjax-container HTTP/1.1" 200 13246 "https://mywebstie.com/scp/tickets.php" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/126.0.0.0 Safari/537.36"
      192.168.55.12 - - [18/Jul/2024:05:26:35 +0000] "POST /scp/ajax.php/form/upload/attach HTTP/1.1" 200 879 "https://mywebstie.com/scp/tickets.php?id=14722" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/126.0.0.0 Safari/537.36"
      192.168.55.12 - - [18/Jul/2024:05:26:35 +0000] "POST /scp/ajax.php/lock/ticket/14722 HTTP/1.1" 200 910 "https://mywebstie.com/scp/tickets.php?id=14722" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/126.0.0.0 Safari/537.36"
      192.168.55.12 - - [18/Jul/2024:05:26:39 +0000] "POST /scp/tickets.php?id=14722 HTTP/1.1" 302 936 "https://mywebstie.com/scp/tickets.php?id=14722" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/126.0.0.0 Safari/537.36"
      192.168.55.12 - - [18/Jul/2024:05:26:39 +0000] "GET /scp/tickets.php HTTP/1.1" 200 6205 "https://mywebstie.com/scp/tickets.php?id=14722" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/126.0.0.0 Safari/537.36"
      192.168.55.12 - - [18/Jul/2024:05:26:39 +0000] "GET /scp/autocron.php HTTP/1.1" 201 356 "https://mywebstie.com/scp/tickets.php" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/126.0.0.0 Safari/537.36"
      I'm just opening a ticket, put a attachment and some text, waiting to "all changes saved" and Reply. In result, i've a test, but without attachment.
      That strange, but i've just install a fresh osTicket 1.18.1, where i can put the attachement in, dot as a text and reply without waiting for "all changes saved" and everything is perfectly saving into datebase.
      Is there a some log file of osTicket, where i can also look for some errors?
        czarek
        The only place in osTicket is the Admin Panel > Dashboard > System Logs. Other than that it's all other logs on your server.
        So there is nothing else i can provide to show what's happening.
        The problem seems to appear more often, when i try to reply to solved or closed ticket. If i reopened ticket first and then try to reply, mostly attachment is appearing
          czarek
          So I see the message in your OP was empty. What happens if you type a message and attach a file? Usually this can indicate session issues. Are there any similarities between devices, etc. where the issue occurs to help narrow this down?
            Problem appears at many different devices, without any scheme.
            There was a dot in the message 🙂 it is impossible to reply without type something as message. I've also waited to "all changes saved" 🙂
              czarek
              Can you try updating these INI directives, restart the web server (and PHP-FPM if you’re running it), and retest? Apache has its own set of upload file size limits, post/request limits, etc. as well.
              9 months later
              Czarek rozwiązałeś problem? Mam dokładnie to samo na 1.18.2?
              I have exactly the same thing on 1.18.2
              EDIT:
              information:
              added two answers with attachment:
              added file:
              file entry was created in the database under id 376 (Table: ost_file):
              exists physically on disk:
              however, no entry was added to the attachment table (Table: ost_attachment):
              what's interesting "drag and drop" always works, problems are with "choose them"
