Hi, is it able to modify the .php to add extra output layout in landing page?
for example like this landing page down below would like to add slide image from .php
if possible would like to be able change from here
if not just from .php would be nice
but if there alternative way to add another this
below it so that can make another output show up in landing page would be great 🙂
just need starting point where do i need to edit to be able do things that i request.
here my information
  • myz
    You can simply modify the Landing Page to your liking. If you want further customizations you'll have to customize the code. If you customize the code you will be on your own as you are deviating from core. Proceed at your own risk.
    myz
    First, you are running a very old and unsupported version of osTicket. You’ll need to upgrade to the latest to get further help. Secondly, if you want to add an image to the Landing Page you simply modify the Landing Page in your screenshots.
    • myz replied to this.
      for add image, not just put image... i mean i want add another divide below it so i can modify code to be able to had sliding image for user to see it
        myz
