the only configuration that works (with all other problems) is with o=cnr,c=it
LDAP plugin not autenticate user, but only AGENT
Did you see this comment?
Yes, but the right config is with o=cnr,c=it and all other as configured
So you’re not going to change the LDAP Servers setting from local host to your actual domain?
localhost is the ldap server, what should I change?
Change localhost to the actual domain. We use that in part of the lookup/search so it might be failing as it’s expecting the domain but getting localhost.
changing it with the fqdn server name does not make changes if i write dc=cnr,dc=it.
it save infos only with the correct basedn that is o=cnr,c=it
My apologies, after re-reviewing the code this seems to be used only if you don't provide a Search Base. At this point I'm not sure what's going on in your case. I tried again but still unable to replicate your issue. I'm hoping someone more verse with LDAP and O-style trees can pop in and provide more input because at this point I'm unsure what your issue is. Error 32 indicates issues with DN, Search User, access/permission issues, etc. so that's about all the suggestions I have based on guides/posts online.
Maybe one of these will help?
- https://support.microfocus.com/kb/doc.php?id=7020594
- https://serverfault.com/questions/883452/using-meta-database-backend-to-combine-active-directory-db-and-openldap-local-db
I am using OpenLDAP (and MSAD) with DC-style trees so this could be the disconnect where yours isn't working as you are using O-style trees. I've never seen this style before here so that's the only thing I can think of at this time. I know you are going to say "but it's working for agents" but Agents use a different auth method than Users. With Users it goes through an additional lookup and sync process:
If you want you can either unpack the plugin or download the raw plugin files and add debug statements and mess with the code yourself to see where it's failing and why. All I can go on is the logs you've provided which simply states Error 32 which isn't that helpful.
alepensato i think you should use servername.domain.it(it in your case) or ipofserver.domain.it
shkodranademi
no this not make any difference the problem is in the code, in my opinion is not a good strategy to have two different methot to authenticate user that are AGENT and CLIENT, authentication of the user is the same, only after that you should change the authorization methos that allow AGENT to to particular operation respect CLIENT
I think a community member has just found the actual root cause:
They will be testing a fix I will be making soon and if it works I will make new builds of the Plugins that should address your issue.
