5 days later
Sorry for the late response.
Clearing the cache and cookies did solve the issue temporarely. The issue is observerd again after using the system for a period of time
    kirandev92
    Yea I can’t replicate that. Do you have multiple people logging in to the same agent account? If so this will be an issue.
      No, we do not have multiple people logging in using the same agent account. Will it be an issue if an agent has multiple tabs open and working on tickets simultaneously?
        This behavior is due to code changes in the upgraded versions? This issue is not seen in v.1.11.0 as pointed out earlier.
          kirandev92
          It honestly shouldn’t affect anything though. Are all your agents using the same IP to access the site? Meaning do you have a intranet or vpn or something that changes their IP to the same IP?
            KevinTheJedi Yes, That is accurate. We use VPN so all the agents will have the Same IPv4. Are you suggesting that this is the root cause of the problem?
              kirandev92
              It shouldn’t be but depending on how you have everything setup it might be contributing to the issue. Do you have Admin Panel > Settings > Agents > Bind Agent Session to IP enabled?
