It appears you have a language pack installed. Please delete the US Holidays schedule (Admin Panel > Manage > Schedules) and retest.
Also, you should upgrade to v1.17.4 or v1.18.
ao tentar atualizar o osticket, recebo a seguinte informação:
Composer detected issues in your platform: Your Composer dependencies require a PHP version ">= 8.1.0".
Nao sei se fiz de forma correta a atualização.
You need to upgrade to PHP 8.1-8.2 for v1.18. If you have to stick with PHP 8.0 you will need to upgrade to v1.17.4.
Alguma dessas versoes serviria?
nessa alteração tivemos esse erro
Configure your PHP to not display errors. Also, configure it to ignore Notices and Deprecation warnings. These can be ignored.
Also, make sure /path/to/osTicket/bootstrap.php
has display_errors
and display_startup_errors
set to 0
Ola amigos!!
ontem percebi que o erro esta no banco de dados, pois quando coloco esse banco de dados em outra instalaçao o travamento do formulario de tickets novos tambem ficam travando.
esses sao os logs do mysql
2023-06-28T19:56:08.335408Z 0 [System] [MY-010116] [Server] c:\wamp64\bin\mysql\mysql8.0.31\bin\mysqld.exe (mysqld 8.0.31) starting as process 1544
2023-06-28T19:56:08.362846Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
2023-06-28T19:56:08.807808Z 1 [System] [MY-013577] [InnoDB] InnoDB initialization has ended.
2023-06-28T19:56:09.563217Z 0 [Warning] [MY-010068] [Server] CA certificate ca.pem is self signed.
2023-06-28T19:56:09.563896Z 0 [System] [MY-013602] [Server] Channel mysql_main configured to support TLS. Encrypted connections are now supported for this channel.
2023-06-28T19:56:09.650700Z 0 [System] [MY-010931] [Server] c:\wamp64\bin\mysql\mysql8.0.31\bin\mysqld.exe: ready for connections. Version: '8.0.31' socket: '' port: 3306 MySQL Community Server - GPL.
2023-06-28T19:58:58.661109Z 0 [System] [MY-013105] [Server] c:\wamp64\bin\mysql\mysql8.0.31\bin\mysqld.exe: Normal shutdown.
2023-06-28T19:58:59.944330Z 0 [System] [MY-010910] [Server] c:\wamp64\bin\mysql\mysql8.0.31\bin\mysqld.exe: Shutdown complete (mysqld 8.0.31) MySQL Community Server - GPL.
2023-06-29T11:01:53.728761Z 0 [System] [MY-010116] [Server] c:\wamp64\bin\mysql\mysql8.0.31\bin\mysqld.exe (mysqld 8.0.31) starting as process 7556
2023-06-29T11:01:53.764789Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
2023-06-29T11:01:54.829265Z 1 [System] [MY-013577] [InnoDB] InnoDB initialization has ended.
2023-06-29T11:01:55.782795Z 0 [Warning] [MY-010068] [Server] CA certificate ca.pem is self signed.
2023-06-29T11:01:55.784038Z 0 [System] [MY-013602] [Server] Channel mysql_main configured to support TLS. Encrypted connections are now supported for this channel.
2023-06-29T11:01:55.843858Z 0 [System] [MY-010931] [Server] c:\wamp64\bin\mysql\mysql8.0.31\bin\mysqld.exe: ready for connections. Version: '8.0.31' socket: '' port: 3306 MySQL Community Server - GPL.
Quais logs sao úteis?? Ainda nao consegui resolver meu problema.
Lohs do PHP
--- File cleaned up by Wampserver ---
--- on 2023-06-29 11:53
[29-Jun-2023 11:54:06 UTC] PHP Notice: Undefined variable: w_testPort82 in C:\wamp64\wampmanager.tpl on line 236
[29-Jun-2023 11:54:06 UTC] PHP Stack trace:
[29-Jun-2023 11:54:06 UTC] PHP 1. {main}() C:\wamp64\scripts\refresh.php:0
[29-Jun-2023 11:54:06 UTC] PHP 2. require() C:\wamp64\scripts\refresh.php:773
[29-Jun-2023 11:54:06 UTC] PHP Notice: Undefined variable: w_testPort82 in C:\wamp64\wampmanager.tpl on line 491
[29-Jun-2023 11:56:16 UTC] PHP Fatal error: Maximum execution time of 120 seconds exceeded in C:\wamp64\www\osticket\upload\include\class.schedule.php on line 682
[29-Jun-2023 11:56:16 UTC] PHP Stack trace:
[29-Jun-2023 11:56:16 UTC] PHP 1. {main}() C:\wamp64\www\osticket\upload\scp\tickets.php:0
[29-Jun-2023 11:56:16 UTC] PHP 2. require_once() C:\wamp64\www\osticket\upload\scp\tickets.php:569
[29-Jun-2023 11:56:16 UTC] PHP 3. Ticket->getEstDueDate() C:\wamp64\www\osticket\upload\include\staff\ticket-view.inc.php:592
[29-Jun-2023 11:56:16 UTC] PHP 4. Ticket->getSLADueDate($recompute = uninitialized) C:\wamp64\www\osticket\upload\include\class.ticket.php:575
[29-Jun-2023 11:56:16 UTC] PHP 5. SLA->addGracePeriod($date = class DateTime { public $date = '2185-06-07 23:59:59.000000'; public $timezone_type = 3; public $timezone = 'America/Sao_Paulo' }, $schedule = NULL, $timeline = uninitialized) C:\wamp64\www\osticket\upload\include\class.ticket.php:557
[29-Jun-2023 11:56:16 UTC] PHP 6. BusinessHoursSchedule->addWorkingHours($date = class DateTime { public $date = '2185-06-07 23:59:59.000000'; public $timezone_type = 3; public $timezone = 'America/Sao_Paulo' }, $hours = 48, $timeline = []) C:\wamp64\www\osticket\upload\include\class.sla.php:55
[29-Jun-2023 11:56:16 UTC] PHP 7. BusinessHours->addWorkingHours($date = class DateTime { public $date = '2185-06-07 23:59:59.000000'; public $timezone_type = 3; public $timezone = 'America/Sao_Paulo' }, $hours = 48, $auditlog = uninitialized) C:\wamp64\www\osticket\upload\include\class.schedule.php:479
[29-Jun-2023 11:56:16 UTC] PHP 8. BusinessHours->initOccurrences($date = class DateTime { public $date = '2185-06-07 23:59:59.000000'; public $timezone_type = 3; public $timezone = 'America/Sao_Paulo' }, $grace_period_hrs = uninitialized) C:\wamp64\www\osticket\upload\include\class.businesshours.php:106
[29-Jun-2023 11:56:16 UTC] PHP 9. ScheduleEntry->getOccurrences($start = class DateTime { public $date = '2185-06-08 23:59:59.000000'; public $timezone_type = 3; public $timezone = 'America/Sao_Paulo' }, $end = '2185-06-08', $num = uninitialized) C:\wamp64\www\osticket\upload\include\class.businesshours.php:78
[29-Jun-2023 11:56:16 UTC] PHP 10. ScheduleEntry->getCurrent($from = class DateTime { public $date = '2185-06-08 23:59:59.000000'; public $timezone_type = 3; public $timezone = 'America/Sao_Paulo' }) C:\wamp64\www\osticket\upload\include\class.schedule.php:851
[29-Jun-2023 11:56:16 UTC] PHP 11. ScheduleEntry->getStopsDatetime() C:\wamp64\www\osticket\upload\include\class.schedule.php:797
[29-Jun-2023 11:56:16 UTC] PHP 12. ScheduleEntry->isOneTime() C:\wamp64\www\osticket\upload\include\class.schedule.php:716
Logs do Apache
--- on 2023-06-28 19:55
[Wed Jun 28 16:56:07.494791 2023] [mpm_winnt:notice] [pid 3884:tid 404] AH00455: Apache/2.4.54 (Win64) PHP/8.1.13 mod_fcgid/2.3.10-dev configured -- resuming normal operations
[Wed Jun 28 16:56:07.494791 2023] [mpm_winnt:notice] [pid 3884:tid 404] AH00456: Apache Lounge VS16 Server built: Nov 2 2022 10:09:33
[Wed Jun 28 16:56:07.494791 2023] [core:notice] [pid 3884:tid 404] AH00094: Command line: 'c:\wamp64\bin\apache\apache2.4.54.2\bin\httpd.exe -d C:/wamp64/bin/apache/apache2.4.54.2'
[Wed Jun 28 16:56:07.497787 2023] [mpm_winnt:notice] [pid 3884:tid 404] AH00418: Parent: Created child process 3424
[Wed Jun 28 16:56:08.092787 2023] [mpm_winnt:notice] [pid 3424:tid 400] AH00354: Child: Starting 64 worker threads.
[Wed Jun 28 16:56:58.267669 2023] [mpm_winnt:notice] [pid 3884:tid 404] AH00422: Parent: Received shutdown signal -- Shutting down the server.
[Wed Jun 28 16:57:00.284669 2023] [mpm_winnt:notice] [pid 3424:tid 400] AH00364: Child: All worker threads have exited.
[Wed Jun 28 16:57:02.257652 2023] [mpm_winnt:notice] [pid 3884:tid 404] AH00430: Parent: Child process 3424 exited successfully.
[Wed Jun 28 16:57:03.698288 2023] [mpm_winnt:notice] [pid 7136:tid 420] AH00455: Apache/2.4.54 (Win64) PHP/8.0.26 mod_fcgid/2.3.10-dev configured -- resuming normal operations
[Wed Jun 28 16:57:03.698288 2023] [mpm_winnt:notice] [pid 7136:tid 420] AH00456: Apache Lounge VS16 Server built: Nov 2 2022 10:09:33
[Wed Jun 28 16:57:03.698288 2023] [core:notice] [pid 7136:tid 420] AH00094: Command line: 'c:\wamp64\bin\apache\apache2.4.54.2\bin\httpd.exe -d C:/wamp64/bin/apache/apache2.4.54.2'
[Wed Jun 28 16:57:03.700284 2023] [mpm_winnt:notice] [pid 7136:tid 420] AH00418: Parent: Created child process 8788
[Wed Jun 28 16:57:04.641279 2023] [mpm_winnt:notice] [pid 8788:tid 448] AH00354: Child: Starting 64 worker threads.
[Wed Jun 28 16:58:28.587553 2023] [mpm_winnt:notice] [pid 7136:tid 420] AH00422: Parent: Received shutdown signal -- Shutting down the server.
[Wed Jun 28 16:58:58.595421 2023] [mpm_winnt:notice] [pid 7136:tid 420] AH00431: Parent: Forcing termination of child process 8788
[Thu Jun 29 08:01:52.694905 2023] [mpm_winnt:notice] [pid 9084:tid 396] AH00455: Apache/2.4.54 (Win64) PHP/8.0.26 mod_fcgid/2.3.10-dev configured -- resuming normal operations
[Thu Jun 29 08:01:52.694905 2023] [mpm_winnt:notice] [pid 9084:tid 396] AH00456: Apache Lounge VS16 Server built: Nov 2 2022 10:09:33
[Thu Jun 29 08:01:52.694905 2023] [core:notice] [pid 9084:tid 396] AH00094: Command line: 'c:\wamp64\bin\apache\apache2.4.54.2\bin\httpd.exe -d C:/wamp64/bin/apache/apache2.4.54.2'
[Thu Jun 29 08:01:52.696898 2023] [mpm_winnt:notice] [pid 9084:tid 396] AH00418: Parent: Created child process 7724
[Thu Jun 29 08:01:53.310910 2023] [mpm_winnt:notice] [pid 7724:tid 412] AH00354: Child: Starting 64 worker threads.
The 'wampapache64' service is restarting.
TThu Jun 29 08:54:02.254314 2023] [mpm_winnt:notice] [pid 9084:tid 396] AH00424: Parent: Received restart signal -- Restarting the server.
[Thu Jun 29 08:54:03.135218 2023] [mpm_winnt:notice] [pid 9084:tid 396] AH00455: Apache/2.4.54 (Win64) PHP/8.0.26 mod_fcgid/2.3.10-dev configured -- resuming normal operations
[Thu Jun 29 08:54:03.136223 2023] [mpm_winnt:notice] [pid 9084:tid 396] AH00456: Apache Lounge VS16 Server built: Nov 2 2022 10:09:33
[Thu Jun 29 08:54:03.136223 2023] [core:notice] [pid 9084:tid 396] AH00094: Command line: 'c:\wamp64\bin\apache\apache2.4.54.2\bin\httpd.exe -d C:/wamp64/bin/apache/apache2.4.54.2'
[Thu Jun 29 08:54:03.138218 2023] [mpm_winnt:notice] [pid 9084:tid 396] AH00418: Parent: Created child process 7004
[Thu Jun 29 08:54:03.645947 2023] [mpm_winnt:notice] [pid 7004:tid 396] AH00354: Child: Starting 64 worker threads.
[Thu Jun 29 08:54:04.271751 2023] [mpm_winnt:notice] [pid 7724:tid 412] AH00364: Child: All worker threads have exited.
I mentioned above in this reply that you need to delete the US Holidays Schedule.
Deu certo meu amigo!!! Eu jamais imaginaria que a solução seria essa!!! Muito Obrigado pela ajuda.
