Will give it a try and report back, thanks.
Authentication config button no longer working
The authentication selection is now empty. I can again select "OAuth2 - Microsoft". The "config" button turns into orange. But a click on config does NOT show the config window.
System logs do not show any related entries.
There are more logs than just system logs...(general server logs, webserver error logs, PHP error logs, MySQL/MariaDB error logs, osTicket System Logs, Browser Console logs, etc.)
nginx logs says
400 POST /scp/ajax.php/email/1/stash HTTP/2.0
That doesn't tell us much of anything other than that was a failed request. Do you have the appropriate NGINX rules? You can look at previous threads for people posting their working NGINX rules.
I have reset my nginx modifications but page does still not appear (only to be sure that my changes have not introduced the problem),
I have added this part
location ~ ^/api/(?:tickets|tasks|auth).*$ {
try_files $uri $uri/ /api/http.php?$query_string;
Then you will need to search for the working config from other community members or keep debugging to see if there are any relevant errors with more information.
My problem is not my nginx config. It's back to default.
My problem is that I can't modify the authentication settings any more.
You are saying the Config popup isn't appearing. The popup uses AJAX. AJAX requires NGINX rewrite rules. If the popup is not appearing then you either have a fatal error being logged somewhere or the rules are not correct. Or maybe even borked codebase (like missing files, copy/replace didn't work fully, etc.).
I'm running osTicket on Plesk with nginx as proxy in front of apache.
Plesk somehow damaged the config files. I have now restored my configuration from backup and the button is working again.
However I'm now back to the callback issue. I get a valid token but the callback gives me "URL not supported".
My nginx rule looks like this
That seems to work, because the log shows it's redirected to /api/http:
93.219.167.161 - - [27/Jan/2023:14:37:31 +0100] "GET /api/http.php?code=0.AV0Aw...-af7e-92ed872a25a6 HTTP/1.0" 400
What I'm missing?
Regards
Martin
Do you see any other relevant errors in your logs (general server logs, webserver error logs, PHP error logs, MySQL/MariaDB error logs, osTicket System Logs, Browser Console logs, etc.)? 400 doesn't tell us much.
Checked all, no php errors, no db errors, no browser errors, no osTicket errors.
Doing a quick google search says that your server is denying the request because Some common causes of the 400 bad request error are: Malformed URL syntax – the URL may contain invalid characters such as {, }, [, or ].
. Seems NGINX is causing more issues than what it's worth. You should really use a supported webserver like Apache/LiteSpeed/IIS.
