Raul1617
You are using an old version that had bugs. You need to upgrade to one of the latest versions and retest.
Muchas gracias por su respuesta, existe algún manual o pasos para poder hacer el Upgrade?
gracias.
    4 months later
    Hi, I have the same problem, just now, Im have the last version of osticket, this happened after install a SSL certificate...
      cbr_net
      You need to check your logs (general server logs, webserver error logs, PHP error logs, MySQL/MariaDB error logs, osTicket System Logs, Browser Console logs, etc.) for any related errors.
      Kevin thanks,
      I reviewed the logs, however, there isnt nothing about this situation, I removed the certificate and the problem persist, I let know that the problem is only in the new tickets, the previous tickets open normally (these tckets where created in the 1.15 version), but the new tickets (created in the version 1.17) not be open correctly
      And the previous ticket works without problem
      After some test I know that the problem is the version 1.17, I tried to create a new ticket manually and the problem is here (in the creation)
      Here the logs...
      This error happend always, if I up the memory and the time....
        cbr_net
        No worries! It’s a bug with translated dates that we are looking to address in future updates.
        2 years later
