junosapien Also, since you are using Linux/Apache the cgi.fix_pathifo isn't really that critical for you.
I am on 1.15.8 and do not have the issue you mention above. It has been most likely fixed in on of the subsequent patches since .4 was released. It also looks like you might be using some customization on the pages as well. If so, that could be breaking it.
