i'm not native english...
and I dont see sequence in menu...just random
I check documentation and miss this "sequence" option..how can I fix it?
    caygri
    Then you probably have a fatal error somewhere. Please check all your logs (general server logs, webserver error logs, PHP error logs, MySQL/MariaDB error logs, osTicket System Logs, Browser Console logs, etc.) for any related errors.
    2022-08-25 12:44:40	Error	80.182.96.33		AH01071: Got error 'PHP message: PHP Fatal error: Declaration of GoogleAuth2FAPlugin::uninstall() must be compatible with Plugin::uninstall(&$errors) in phar:///var/www/vhosts/site.com/supporto.site.com/include/plugins/2fa-gauth.phar/googleauth.php on line 18', referer: https://supporto.site.com/scp/emails.php?id=1				Apache error
    2022-08-26 11:47:33	Warning	103.93.9.190		mod_fcgid: stderr: PHP Fatal error: Uncaught Error: Call to a member function getTabs() on null in /var/www/vhosts/site.com/supporto.site.com/include/staff/templates/mobile-navigation.tmpl.php:2, referer: https://supporto.caygri.com/scp/index.php				Apache error
    i have this
      caygri
      The top warnings about ::uninstall() are fine (although you really need to update your plugins). The main concern here is mobile-navigation.tmpl.php file. This does not exist in the core code which means you have customizations applied and is likely contributing to your main issue. Please remove ALL mods and retest. You can even make a fresh install with no mods to see if you see the same issue there.
      P.S.
      Next time you post errors be sure to censor any sensitive information (such as your domain name).
      i have also a new installation in english same problem...
        caygri
        What are your environment details? I cannot replicate this issue at all.
        it's a dedicated server with ubuntu 20 and plesk installed. php 8 and maria db
          caygri
          I have v1.16.3 + PHP 8.0.x + MySQL 8.0.x + Apache and cannot replicate this issue. Mine has the defaults and it allows me to add as many as I want.
          how can i do? how can send you data and pay it for fix it?
