Same issue here
  • Chrome 101.0.4951.64
  • osTicket (v1.12)
Everyone,
We don’t develop the text editor so seeing it replicated isn't necessary. We have opened a ticket with the developers of the text editor. We are now awaiting an update from them.
Here is a workaround for 1.16.2 file: support/include/staff/ticket-view.inc.php starting at line 1044:
Add a <br> after the input line.
No idea why it works or if this is the best workaround, but it works for me πŸ˜‰
<input type="hidden" name="draft_id" value=""/>
<br>
<textarea name="response" id="response" cols="50"
data-signature-field="signature" data-dept-id="<?php echo $dept->getId(); ?>"
data-signature="<?php
echo Format::htmlchars(Format::viewableImages($signature)); ?>"
placeholder="<?php echo __(
'Start writing your response here. Use canned responses from the drop-down above'
rows="9" wrap="soft"
class="<?php if ($cfg->isRichTextEnabled()) echo 'richtext';
?> draft draft-delete fullscreen" <?php
list($draft, $attrs) = Draft::getDraftAndDataAttrs('ticket.response', $ticket->getId(), $info['response']);
echo $attrs; ?>><?php echo ThreadEntryBody::clean($_POST ? $info['response'] : $draft);
?></textarea>
    emmanuelsf My favorite coding technique trial-and-error. . And a little prayer πŸ˜‰
    And I looked at the code for the Note Details tab and saw it did not have a <input just before so I tried adding a <br> and that worked.
      jarnott
      I will test this out and make a pull if it works. We will still await an update from the developers for a permanent solution.
      5 days later
      I created an account just to say thank you to @jarnott and @KevinTheJedi for this fix.
      I've been playing around setting up and testing OSTicket for about 3 weeks without seeing this issue, one day after I put it into semi-production I start seeing this problem in Chrome. Bizarre! I guess I never deleted back to the beginning of the reply form in my testing...
      12 days later
      3 months later
