Hi Support,
Recently Microsoft has intimate us that, they are going to remove IMAP and POP. Only SMTP Authentication will work that too old SMTP will not work.
Is there any workaround or fixes or release by OSTicket?
  • @asit
    Most people create an app password and it works that way.
@asit
    Thank you Kevin! I will try with app password.
    Is there any workaround for pop and IMAP?
    as Microsoft is going to stop IMAP and POP.
    @asit
    You mean they are going to disable Basic Authentication on the IMAP and POP protocols. We are working on OAuth2.0 support that should be available soon.
      Yes Kevin. Microsoft is going to disable Basic Authentication on the IMAP and POP protocols.
      Thank you for letting me know, I will wait for OAuth2.0 release 😀.
