I recently attempted to upgrade my OsTicket install from v1.10 to v1.12.2. I set the system to offline mode, made a backup, copied and replaced the files, copied over my ost-config.php file and browsed to the URL. I was able to see the admin login page but when I try to login I get the message "System Offline" above the login.
I did run the mysql command update ost_config SET isonline='1'; but I am still getting the same message.
I have tried searching the forms and on Google but I can not seem to find anything that would cause this other than the setting isn't correctly set.
