ntozier Hi, thanks for the continued assistance. That's what it was set to at teh beginning, I tried the other settings in case it would make a difference.
If you have a working environment set up, no matter what the version, could you please try to set up one to see if it works? I tried in 1.10.7 and 1.12.3 and couldn't get it to work at all, I'm thinking that maybe the filter just doesn't work? Otherwise, if it works for you, we could probably figure which settings is not properly set at my end.
