I have Cpanel and configured it many different ways in hopes to get an email sent to support@ piped directly to osTicket. So far, it has failed. I am pretty sure this syntax is correct.
public_html/support/helpdesk/upload/api/pipe.php
however, it refuses to work and the email is returned with nothing showing up on osTicket.
Any ideas? I saw a post earlier mentioning editing /etc/php.ini but I have no such file in my shared server /etc directory.
Thanks
6 days later
You have to change the permissions on the pipe.php file so that it has execute permissions.
Thanks
Hi, the location is wrong.
Here is what i used and it works:
/home/YOUR-CPANEL-ACCOUNT-NAME/public_html/LOCATION-TO-OSTICKET/api/pipe.php
Also ensure pipe.php is set to 755 permissions.
hope this helps.
