What version of PHP is located at: #!/usr/bin/phpYou may need to take a look at GoDaddy's PHP versions (they usually run several at the same time) and change that to point to 5.3+note: thats the first line of the rcron.php
php version on scccren
PHP Version 5.6.0
#!/usr/bin/php5.3+ -q ? rcron.php ?
you want 5.3, 5.4, or 5.5. And your web control panel does not indicate the version that resides at #!/usr/bin/phpYou should find out from your host support their path to php5.3+ and change that line in the file.
i set php5.3 not work rcron
HTTP/1.1 404 Not Found Date: Fri, 20 Nov 2015 19 GMT Server: Apache/2.2.16 Vary: Accept-Encoding Connection: close Transfer-Encoding: chunked Content-Type: text/html No input file specified
sounds like you have a .htaccess issue thats redirecting and breaking things.
in api .htacces <IfModule mod_rewrite.c>RewriteEngine OnRewriteCond %{REQUEST_FILENAME} !-fRewriteCond %{REQUEST_FILENAME} !-dRewriteCond %{REQUEST_URI} (.*/api)RewriteRule ^(.*)$ %1/http.php/$1 </IfModule>
and ?
auto-cron is working ......
help me who can fix `?
It looks like your rcron.php is only accessible via http://zocker4ever-gaming.de/rcron.php and not via http://support.zocker4ever-gaming.de/rcron.php
You could also try a third party cron service. Such as:https://www.easycron.com/cron-job-tutorials/how-to-set-up-cron-job-for-osticket
