Hi,could you check my nginx config?server { listen 80; server_name mydomain.com; access_log /var/log/nginx/ost.access.log; error_log /var/log/nginx/ost.error.log;. root /home/www/mydomain.com; index index.php index.html index.htm; location ~ /include { deny all; return 403; }. set $path_info "/home/www/mydomain.com";. if ($request_uri ~ "^/api(+)") { set $path_info $1; }. location ~ ^/api/(?|tasks).*$ { try_files $uri $uri/ /api/http.php?$query_string; }. if ($request_uri ~ "^/scp/.*\.php(+)") { set $path_info $1; }. location ~ ^/scp/ajax.php/.*$ { try_files $uri $uri/ /scp/ajax.php?$query_string; }. location / { try_files $uri $uri/ index.php; }. location ~ \.php$ { include fastcgi_params; fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name; fastcgi_param PATH_INFO<-->$path_info; fastcgi_index index.php; fastcgi_pass unix:/var/run/php5-fpm.sock; } }2015/09/16 10 26253#0: *10878 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client.165.119.0, server: mydomain.com, request: "GET /ajax.php/config/client HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "mydomain.com", referrer: "http://mydomain.com/tickets.php"
