When i try to click the right user it does not populate the form field but when i use enter key its working. When i open it in internet explorer arrow up and down does not work to select the drop down list .
screen shots
This works fine on my installation.What web browser?Are you running a language pack?You might want to upgrade to 1.9.5.1. (which is what I'm running.)
it works fine in chrome but not in IE . btw i use same version as yours. 1.9.5.1 with arabic language pack.
Can confirm this issue here:IE: not workingChrome: workingFirefox: workingSo my guess is that is related to IE somehow, but I have no idea how to start troubleshoot that little usability glitch in IE.
Try Compatibility Mode?
Good idea ;)
i did all that stuff . even the arrow key not working when i drop down the selection.
Are you using any sort of pop up or script blocker plugins on IE?I ask mainly because ABP makes it not work under Firefox until I disabled it for my internal site, so I thought that it might be likely that you had a similar issue.
