Instead of searching PHPmyAdmin I guess you will need to alter the source files ;)
Unfortunately I can't tell you which file or files you need to change to achieve it, but I guess you should may start by having a look at the /include/staff/ticket-aaaaaaa.inc.php files (aaaaaa = there are several files, all start with ticket, but then the file name differs, so I just used aaaaaaaa as wildcard ;) )
