Is there any reason OSticket can't exist alongside another PhP application?
None at all.Wiki doesn't say anything at all about a PhP configuration - other than PhP needs to be installed.
Any help at all appreciated
-Josh
It might help to post the output of phpinfo.php (if it's on your system). Other than that, the 500.19 error generally signals a server misconfiguration. I'd Google that and see if anything helps. Are you trying to run multiple virtual hosts? There may be a conflict in the host config files.Jack
