I am having a rather odd issue and I am unable to identify the culprit. I have searched the forums but cannot find a similar issue nor a solution.
Version: 1.6 ST
Enable POP/IMAP email fetch: enabled
Enable email piping: disabled
New Ticket Alert: Enabled
recipient set to: Admin and Dept Manager
cron.php is set up to run every 5 minutes. On completion of the script the email batch is collected and always creates a ticket. Frequently when a support issue comes through the email the message body will come through properly in the Alert email that is sent out to the Admin/Dep Manager but when you go into the ticket the message body is either completely blank or missing half of the msg.
I am able to replicate the issue and have tried changing database type to "Long Text" just in case and am still producing he same issue. I am also able to replicate this issue on 1.7 DPR4.
Other questions:
External Help: We have external "help" that handle support issues who will NEVER have login access to the system that internal staff will need to forward onto other external parties to resolve. Once the issue is resolved the external party will respond via email to the ticket and the internal staff will notify the original person having the support issue.
Email ticket support: Is there a way to open, close, update and delete a ticket via email rather than logging into the system? For example a CSR takes an incoming call and creates a ticket the dept manager then gets a notification. In the meantime the dept manager gets a separate issue via standard email, resolves the issue and would like to add their updated correspondence and resolve the original ticket number that the CSR created.
Any thoughts or direction would be helpful.
